Old 06-07-2002, 09:47 PM   #1
oktay
e30 timing belt broke at 100K and done a valve job
The oil light is on and the inspection light is on red(very last one)
What kind of problems should I expect from this vehicle?
TIA
What is mod?
oktay is offline   Reply With Quote
Old 06-08-2002, 02:45 AM   #2
Dave 325i
not sure i understand clearly . . .
Is this a car you're looking to buy?
By valve job, do you mean like performance regrind / reseating etc. or just adjusting the valves?
When a timing belt breaks on an E30, the valves don't move in sync with the pistons, which means the pistons will smash into the valves. Valves will be bent, holes in pistons, etc. Car won't run.
Maybe the previous owner had the valve job after the belt break as a repair?
The oil and inspection lights are just reminders to change the oil and have an inspection done on the car. They can be reset. I guess it means the the previous owner was too cheap to do the maintenance, or did it and did not reset the lights.
Dave 325i is offline   Reply With Quote
Old 06-08-2002, 01:59 PM   #3
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
I reset my insepction lights they where off for a day then came back...
Stanceiseverything.com
Old 06-09-2002, 05:59 PM   #4
swisherchico
SI Batteries dead
If you reset your service indicator lights and they come back to the red and yellow, that means your SI (service indicator) batteries are dead, you need to take out the gauge cluster to have them replaced. www.bmwe30.net has some step by step instructions on how to complete this process.
swisherchico is offline   Reply With Quote
