Old 05-05-2004, 05:08 AM   #1
Autotechnica
BMW Traitor
here can I find a 12V PS in the engine bay?, only turns on with ignition
Where in the engine bay can I find a 12V power supply that only turns on and off with the ignition? I'm trying to frind a PS for my electric engine fan.
Any ideas?
thanks,
Bryan
'02 Mercedes C32 AMG 3.2L Supercharged @ 18psi - 341WHP/358lbs*ft TRQ (DynaPak) Eurocharged custom tune, ASP 178mm crank pulley + PSK, CM30 i/c pump, i/c iso kit, Magnecore wires, NW CAI, dual custom exhaust, H&R sway bars, H&R SS coilovers, KMAC camber kit, H&R spacers, Quaife ATB LSD, goodridge SS lines, Porterfield RS4 pads, AMG 18" rims, AEM UEGO wideband, Dashdaq datalogger, Kenwood Excelon DNX8120
Old 05-05-2004, 12:27 PM   #2
MarkD
MarkD's Avatar
If your car has daytime running lamps, you could take it from there. And if you wire in a thermo switch that is mounted in the radiator you don't even need a switched 12V, the switch will turn the fan on when the rad heats up. That's what I did on my 2002tii.
MarkD
