Old 05-05-2004, 05:06 AM   #1
Autotechnica
Little Chino
Problem with engine overheat!, Installed new rad and refilled coolant
I just swapped out my stock rad because it was damaged for a replacement which is the same make. After I reinstalled the rad and all the hoses I start the car and after a while it starts to overheat. Is the coolant getting to the engine properly? I filled it to the "Kalt/Cold" line while the engine was cold. Even with my fan on full blast the engine overheated. It can't be the fan, so it must be the coolant or rad. Any ideas on what's wrong? The coolant level was about 1cm below the "cold" mark. Would this cause the engine to overheat?
Thanks,
Bryan
Old 05-05-2004, 06:19 AM   #2
R_JAY
Has the world for ransom
Bry, try bleeding the system again. It sounds like you have some air trapped in there. I used this link when I did my flush. I don't know if it differs from the 318 but it should give you an idea.
http://www.logun.org/radflush.htm
Old 05-05-2004, 06:23 AM   #3
tiestoE36
tiestoE36's Avatar
ya i think for sure an air lock
tiestoE36 is offline   Reply With Quote
Old 05-05-2004, 02:00 PM   #4
NickP
NickP's Avatar
Also make sure that when you're doing this that you have your heater on full hot.
Old 05-05-2004, 02:30 PM   #5
2slow2race
2slow2race's Avatar
im thinking its a air lock
saw it on tv
the guys car was overheating cause there was air in the line and in the system
get the air hose out
2slow2race is offline   Reply With Quote
Old 05-05-2004, 06:17 PM   #6
Russian325is
Russian325is's Avatar
Send a message via ICQ to Russian325is Send a message via MSN to Russian325is
hmm...i would agree on th air lock....
try bleeding it..if it insists...
then i would say that it's the water pump....the stock water pump came with plastic fins (easily broken with time and heat)...and the updated version of the water pump for the e36 come with metal fins....
Life's short, live fast...drive a BMW...
2008 335i (e92) (current)
1994 325is (sold)
1992 535i (sold)
1993 525i (totaled)
Russian325is is offline   Reply With Quote
Old 05-05-2004, 06:38 PM   #7
Gurvinder
i agree with Russian325is i just went threw this like 2 weeks ago
Gurvinder is offline   Reply With Quote
Old 05-05-2004, 06:40 PM   #8
Autotechnica
Little Chino
Ok thanks guys, I did this and fixed the overheat problem.
Here's another problem. I fill up the coolant in the top off tank to the "cold" mark when the engine's cold. I start the car and run it till it's warm, all the coolant in the top off tank is gone. I fill it to the mark again, start the car and minutes later the coolant is gone once again. Do I just keep filling it up like this until it stays at the max mark or what? It's not leaking, I checked.
Thanks,
Bry
Old 05-05-2004, 06:49 PM   #9
Gurvinder
did u just do a flush if so i im guess it would need to refill the whole system again
Old 05-05-2004, 06:50 PM   #10
Russian325is
hmmm...
no leaking...
try filling it up with the engine running...
1994 325is (sold)
1992 535i (sold)
1993 525i (totaled)
Old 05-05-2004, 06:58 PM   #11
Autotechnica
Little Chino
Originally posted by Russian325is
hmmm...
no leaking...
When I fill it while the engine is running, should I also remove the vent cap? Also, do I fill to the "cold" mark while the engine is running?
Thanks,
Bryan
Old 05-05-2004, 07:37 PM   #12
tiestoE36
tiestoE36's Avatar
Thanks,
Bryan
I wouldnt do that, I would run the car, then turn it off and let the engine cool off, as well as the coolant.
once every thing is cooled own check the level, if you need to add then add more.
the coolant expands and contracts to different engine temps, so i really wouldnt fill it while its running.
Old 05-05-2004, 07:42 PM   #13
Autotechnica
Little Chino
Ok thanks for your helps guys. I topped it off and used 2 full bottles 9L of mixed Prestone coolant. I must have drained almost all of it when I removed my rad. I never drained it from the block though.
Anyways, now it reaches the mark properly when the car is on and off.
You guys were a great help.
Bry
Old 05-05-2004, 08:19 PM   #14
BMW_M52_M20
When my old e36 had a new rad put in it took a while for the whole coolant light to go off, kept filling it up and then it stopped.
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 05-05-2004, 08:20 PM   #15
BMW_M52_M20
Bry
I am pretty sure BMW recommends not to use prestone. Just the heads up.
1986 325e (E30)
