Old 05-02-2004, 04:18 PM   #1
E30 tire size
Would 205/40/17 be the correct tire size for an E30?
or is it to small
Old 05-02-2004, 04:20 PM   #2
Jordan
205 is pretty narrow.
215/40/17 is good for a 17x7 or 7.5 wheel. You should only run 205 if the offset of the wheel wont allow for a larger width.
Old 05-02-2004, 04:30 PM   #3
ok thx, aside from being a bit narrow, would the outside diameter(or Circumference or watever) be within limits? Speedo wont be off?
Old 05-02-2004, 06:02 PM   #4
M50E30
www.bmwclub.ca
M50E30's Avatar
205/45/17 is 24" which is the perfect diameter for an E30. I always use www.tirerack.com to find the proper size and then click on the specs of that tire you want to make shure it is with in 3% plus or minus of your stock diameter.
Old 05-03-2004, 04:03 AM   #5
thx i found a alittle program
Tire Size Program
185/65/14 - - - - - - - - - - - - - - - -205/40/17
Tire Diameter (inch): 23.47 - - Tire Diameter (inch):23.46
Tire+Wheel Radius (inch): 11.73 Tire+Wheel Radius (inch): 11.73
Tire Circumference (inch): 73.73 Tire Circumference (inch):73.69
its 0.05 of an inch smaller, but i dont think it will make a big diff in the speedo
Old 05-03-2004, 05:10 AM   #6
Kid
Send a message via AIM to Kid
why would Tirerack give the wrong dimensions?
Is there a reason that they would do that?????
-Jason
Kid is offline   Reply With Quote
Old 05-03-2004, 03:26 PM   #7
The stock size is 195/65/14 man.
And you can just go here: http://www.miata.net/garage/tirecalc.html
