Old 04-29-2004, 03:21 PM   #1
Skunk#1
Smile axles what brand
so i am rebuilding everything on my ragged out car, the half shafts have gone out and was wondering about what they should cost. have seen them anywhere from $20-$700 a piece. what brand would you use? saw this site and it shows what i am talking about unless i am reading it wrong.....
http://www2.bimmerpartswholesale.com...bly&category=K
thanks.
BMW--Because Mine Won
Old 04-29-2004, 03:56 PM   #2
felixthecat
Was touched by Micheal
felixthecat's Avatar
factory original parts for that...nothing but,,
Old 04-29-2004, 08:39 PM   #3
Skunk#1
they are so expensive, fu####g $hit. damn i got eibach springs and all the poly bushing and aluminum control arms offset Bushing and a new m3 rack for the same price as bmw want for those half shafts!
Old 04-29-2004, 10:09 PM   #4
felixthecat
i can give you a slightly used set for 300$installed...you're gonna get what you pay for..go cheap, and you'll be doing it again soon,get the good ones your good for 250000kms...your choice
Old 04-29-2004, 10:15 PM   #5
he's in texas felix, do $300US shipped
Old 04-29-2004, 10:17 PM   #6
felixthecat
i like the way your thinkin trev...americans
yeah 300 us shipped is what i meant...
Old 04-30-2004, 01:17 AM   #7
Spaz
Crazy Canuck
Spaz's Avatar
Send a message via AIM to Spaz Send a message via MSN to Spaz
btw, you will not where through axles at any highspeed. if you look at bmws since the axles go up and down only...unlike a fwd car you will not wear out axles, i still have stock ones in my car...and they do not make a single noise....best bet is to go with mevotech axles....i'm pretty sure they're guarrenty for life.
Spaz is offline   Reply With Quote
Old 04-30-2004, 06:01 PM   #8
Skunk#1
yeah, but i just found out that my car has an m3 diff with a locker or spool in it. it has jacked my half shaft all up. also it is messing up the tires. i just resently got under the car (too many projects) to start rebuilding it. was going to replace driveshaft and ring and pinion, but neither where the stock ones. i just thought that these cars had a real stiff lsd, i am replacing this crap thing with a 60% lsd. the car is sitting on my lift with no rear end. thanks for the info, bmw has already taken too much of my money, whats a little more?!
