Old 04-25-2004, 11:50 PM   #1
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Brake Problem
I have been having a problem on and off recently of all 4 of my brakes locking onto the rotors at times when I don't want them to (ie on the highway).
This means that I can be on the highway in 5th gear feet to the floor and cant get past 120km
I got new pads and a brake serviced at chucks to see if they could find anything wrong and after it cost me quite a bit 2 days later the problem happened again. None of my cailpers are seized and other than this the brakes are in perfect order.
What could cause this?
Note:
-I dont have to push the brakes for this to happen
-It occurs and stops whenever it wishes
-When it occurs pedal pressure is significantly different (harder pedals higher)
-Smells like shit after driving like this
Stanceiseverything.com
Old 04-25-2004, 11:56 PM   #2
hmm so all of a sudden it comes on.
Are sure its not when u step on it, it doesn't release fully?
No ABS right? I guess it might be the master cyclinder but i dont see why it would come on all of a sudden.
Maybe a brake fluid flush will help?
Dare I squeeze
Old 04-26-2004, 12:30 AM   #3
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
No abs, or if I have abs it doesnt work.
I might flush the fluid soon thats what I'm thinking may contribute to the problem
Old 04-26-2004, 01:21 AM   #4
Slowered318
Slowered318's Avatar
seized caliper? make shure your car is cool.. then take it out for a 10 min drive try to avoid hard breaking.. pull off to the side and what ever rim is hot.. should be the one with the problem
Slowered318 is online now   Reply With Quote
Old 04-26-2004, 02:39 AM   #5
Jordan
85 325e does not have ABS.
Sounds like a faulty and failing master cylinder.
Old 04-26-2004, 03:42 AM   #6
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
When it does it ALL the rims are hot.
Jordan you said that before. I was just hoping it was something else since I doubt those are cheap. Is there anyway to no for sure?
Old 04-26-2004, 04:24 AM   #7
Jordan
its VERY easy to swap out a MC. Just get a known good used one. People on R3V are always parting out cars.
FYI make sure to get a non-abs one off a early eta.
Old 04-26-2004, 05:16 AM   #8
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
I just read about replacing it in my Haynes manual. Seems fairly simple, much simplier than swapping springs and struts.
I'll keep an eye out for one.
Old 04-26-2004, 02:00 PM   #9
BMW_M52_M20
Master cylinder or brake booster? A customer has the same issue and it was the brake booster because of a vaccum problem with the brakes and the calipers would hold sometimes.
Do you have any scaring or deep lines on the rotors?
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 04-26-2004, 03:35 PM   #10
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Somewhat ya.
Old 04-26-2004, 09:01 PM   #11
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
The rear rotors are def scarred. Front somewhat.
Its getting worse. Foot to the floor in forth gear on derry and I couldn't pass 80km.
Old 04-26-2004, 10:40 PM   #12
e30-323ti
bimmerbushi on bimmerforums had a similar problem, duuno what is was or if he has fixed it, drop him a line.
292rwhp E30
e30-323ti is offline   Reply With Quote
Old 04-28-2004, 03:26 PM   #13
punnzzells
punnzzells's Avatar
Send a message via MSN to punnzzells Send a message via Yahoo to punnzzells
it sounds like it is a faulty brake booster or master .... when you brake do you get a lot of vibration and shaking in the steering wheel?
I have a similiar problem, but I think that my caliper is sticking.... brakes can be a big pain in the ass!
mike.
punnzzells is offline   Reply With Quote
Old 04-28-2004, 03:35 PM   #14
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
I got a new master installed.
Ya mime Id would virbate a lot
Old 04-28-2004, 05:31 PM   #15
did it fix the problem?
Dare I squeeze
