04-21-2004, 12:44 PM
#1
Mr. Euro E30
Car: 1993 BMW 320i (sold), 1989 BMW 325is
Door L O C K E D
I just found this problem yesterday morning, when I tried to unlock the driver's door, it felt a bit hard. Then I figured out the door wont lock after, it only locks if I'm inside the car, the key doesn't work to lock the car :shock:. Then, my passenger door wont open, the door lock knob wont go up :?, it wont open from outside either ... I've checked the fuse #27 which control the central lock, and the fuse is fine.
04-21-2004, 04:16 PM
#2
Car: e36 m3
Ok so when you turn the key to open your car, do both doors open? or jus the driver door?
Did you try the passenger sider door and the trunk to see if its the driverside door lock thats the prob, or if its the central locking system thats not working properly
During the winter i broke my spare key in the driver side door lock  It was cold and the lock was probably frozen, but the damn key broke so easliy.
I have an alarm, so i use that to open and close the doors......when it gets warmer ill try to get the broken key out
04-21-2004, 05:28 PM
#3
Nitrous Junkie!
Car: 91 e30 318is,96 328is
leanord, my moms has the same problem, you have to lock it from the trunk
04-21-2004, 05:52 PM
#4
Mr. Euro E30
did she fix the problem ? i went to vanduc today, he said he has to open the trim. i might just open it on the weekend at adriano's place. are you gonna work on your fender this weekend ? lemme know if you do, cause i'm gonna do mine too, might as well
ps: it LEONARD
04-22-2004, 12:20 AM
#5
Mr. Euro E30
u p !
04-22-2004, 12:23 AM
#6
Nitrous Junkie!
ha ha, sorry i think ive spelled your name different everytime ive spelled it!!!
no she didnt fix it, just keeps walking to the trunk evertime she needs to actually lock the doors..... stupid i know.
i dunno about the fenders this weekend but ill be there
04-22-2004, 03:34 AM
#7
Car: 1987 325es & 1987 325i Cabrio
Hey, guys... I have the same problem in my 87 Cabrio!
Both my driver's and passenger locks don't work! I have to use the trunk lock everytime to lock and unlock the doors.
All the locks work fine from the trunk... but not individually.
Can anyone fill me in on how to correct this probem?
Thanks.
04-22-2004, 11:55 AM
#8
Mr. Euro E30
my trunk wont work either ... i can lock and unlock the trunk normally, but doesn't affect the doors
04-23-2004, 12:46 AM
#9
/OO=[][]=OO\
Car: Cosmosschwarz e39
04-23-2004, 02:22 AM
#10
OMGHI2U2
Car: 03' Lade & 06' M5
can anyone tell me what is R/R in the webpage above?
9 Trunk lock to UNLOCK Trunk unlocks Goto OP #10
Trunk does not unlock If doors unlock, R/R Trunk lock motor and/or circuit
If doors do not unlock, R/R Trunk lock switch
R/R Control Unit if switch and circuit are OK
04-23-2004, 02:29 AM
#11
Car: e36 m3
Replace and reinstall i think,
my uncle uses it when he writes on work orders... Re & Re
04-23-2004, 04:31 PM
#12
OMGHI2U2
thats weird how can you replace the trunk motor if the trunk is shut close? heheh
i'm going to convert drivers/side doors to mechanical locks and then convert the trunk to lever pull lock.
2006 M5 SMG III | Dinan Stage 1 Software
2003 Escalade 8 Seater of Fun - 232k and still running
Sold/Traded-in
2003 M3
2000 M Coupe
1999 M3
1999 323i
04-24-2004, 07:46 PM
#13
Mr. Euro E30
fak ... i couldn't even open my gas filler lid
04-24-2004, 08:22 PM
#14
/OO=[][]=OO\
Qimis did you remove the fuse hence disabled the electrical lock system? From there rip the trunk carpet and pull the filler motor.
I am also having problems with my locks and I removed all the actuators and kind liking it since it is now vey easy to lock or unlock all doors and trunk.
04-24-2004, 10:22 PM
#15
Car: E36 323i, E30 Racecar
On the e30 (i'm not sure about e36) The central locking relay has a shock sensor to throw all the door locks open when you have an accident - I think it can also keep all the doors locked. Might be worth a look.
BMWs Downunder
http://www.bimmersport.co.nz
