Old 04-21-2004, 05:05 AM   #1
la klasic
Registered User
sizing up spacers...help
I installed 18x8 with 225/40 and they hit the front strut.
Any idea how much spacers I will need ??
It did not seem to jam too much as I can still turn my wheels ??
I am guessing 5 to 8 mm !!
Also,
Has anyone run with wheels rubbing against other locations besides the strut or fenders ??
la klasic is offline   Reply With Quote
Old 04-21-2004, 05:13 AM   #2
punnzzells
punnzzells's Avatar
Send a message via MSN to punnzzells Send a message via Yahoo to punnzzells
What did you get?
I talked to my buddy Paul at Delta today and he has a set of 17's that are direct bolt on , no spacers needed... he wanted to unload them too... oh well...
if you hit the front strut, then you would need to see what the offset of the wheel is and then decide from there... if the wheel is an Et 33 or more than you may need a 10 mm spacer.... I think...
mike.
punnzzells is offline   Reply With Quote
Old 04-21-2004, 12:09 PM   #3
EMPOWERD
EMPOWERD's Avatar
it all depends on the most important piece of information you left out!.... the OFFSET. What offset are your wheels? I can tell you right away what size spacer is required. You'll need to end up with a +25mm offset in the end, so if your wheels are ET+40mm.... you'll need a 15mm spacer to acheive the E30 required +25mm (subtract).
Hope this isn't too confusing... read it over again, it'll make sense eventually.
P.S. If your car is lowered, 225/40 tires will rub the outside front fender when turning... even with the proper offset because its too tall for the E30. Maximum 18" tire that will fit under the fender is a 225/35.... I've tried this already on my car.
My YouTube video
-- RANDY SPARRE --
Old 04-21-2004, 12:29 PM   #4
BimmerKris
BimmerKris's Avatar
i've seen 19's on an e30. the car was lowered an inch but i don't know what was done to make them fit, but it was bad ass.
www.eulogy.ca PURE CANADIAN METAL
BimmerKris is offline   Reply With Quote
Old 04-21-2004, 01:40 PM   #5
An 8" wide wheel with 225 width tires will rub the driver's rear shock with ET25. You want about 18-22 offset. You'll likely also need to roll the fenders.
Old 04-21-2004, 02:19 PM   #6
la klasic
Registered User
I have not yet put the cash down....but they are nice rims and if they fit it will be great. Unfortunately, my car is being worked on at Eurodesign (MtechII intall) and I cannot have access to it easily .
The offset is close to 30 to 35 as per my measurements.
The car is not dropped....and will not be.
The rear fit good no problem, the front barely hits (wheels turned when bolts tight).
Any other spots that could hit besides the strut and fender, what about when the wheel is totally turned to one side ?
Any spacer suppliers.....you recommend ?
Old 04-21-2004, 02:19 PM   #7
bmdoubleya
bmdoubleya's Avatar
www.bmpd.com
Look on this link for H&R hub centric wheel spacers.......
bmdoubleya is offline   Reply With Quote
Old 04-21-2004, 02:43 PM   #8
Wait, are you lowering it at all? A non-lowered E30 on 18's is going to look hilarious.
Try www.amimotorsports.com for spacers. Support Canada and maX, they're a sponsor.
Old 04-22-2004, 01:14 AM   #9
la klasic
Registered User
Thanks I will.
Old 04-22-2004, 03:41 AM   #10
EMPOWERD
EMPOWERD's Avatar
la klasic, your car is looking good at Mike's shop (EuroDesign). I was up there picking up parts for my GT2... he's the one that painted it... amazing work. Looking forward to seeing it complete.
My YouTube video
-- RANDY SPARRE --
Old 04-23-2004, 05:20 PM   #11
la klasic
Registered User
Thanks I am looking forward too.....we are only a month behind!!
