Old 04-20-2004, 03:17 AM   #1
christian
Send a message via AIM to christian
Unhappy Dead fuel pump
hey guys sunday i went out to start my 318i and it started fine but wouldn't idle worth shit, it would sputter around 600rpm, shacking really bad so i would shut it off then tried again same thing! i think its my fuel pump cuz its been making a loud buzzing noise latley and i dont think there was enough fuel flowing to idle right, any suggestions? they are much appretiated, thanx in advanced (sniff sniff)
Extrude honed intake
95 Mustang 5.0 15lbs fuel injectors
Platnum 4 spark plugs
Blaster 2 Coil
racing Ceramic brake pads
*not much to it, but not stock either*
christian is offline   Reply With Quote
Old 04-20-2004, 04:03 AM   #2
snd84318i
snd84318i's Avatar
try warming it up if it does it still check your ide control unit . if the fuel pump didnt work it wouldnt start .
snd84318i is offline   Reply With Quote
Old 04-20-2004, 05:34 AM   #3
felixthecat
Was touched by Micheal
felixthecat's Avatar
Re: Dead fuel pump
change the fuel filter...sounds like the pump is working against the gunk caught in it..,its not the idle air control..when those go it idles wayyyyyy too high...also pull down the cover above your glove box and check that single wire plug to the left hand side of the fuel computer,see if its loose(this is what made my car run awful awile back)..if youve done all that and still no luck...change the pump.
Old 04-20-2004, 02:29 PM   #4
SebSter
SebSter's Avatar
change it asap, before you know it youre gonna get a million other problems turning up..trust me
SebSter is offline   Reply With Quote
Old 04-21-2004, 12:23 AM   #5
christian
hey guys thanx i will try what u said today and see if it helps,by the way felix ur car looks sic!! in your sig what color is that?
Blaster 2 Coil
Old 04-21-2004, 01:14 AM   #6
felixthecat
photoshop blue
Old 04-21-2004, 04:07 PM   #7
chromius
chromius's Avatar
get a fuel pressure guage, then check the pressure. That will tell you if the pump is bad, or if your FP regulator is bad.
