Old 04-06-2004, 07:32 PM   #1
TWELEVIE
Send a message via AIM to TWELEVIE
Wider width in the rear?
I've been searching for rims to puchase but I haven't decided widths. On my stock 330Ci, she's wearing the stock double-spoke M's; 17"x7.5" in the fronts and 17"x8.5" in the rears. I was wondering -- should I keep the staggered set-up or would it be safe to keep the same widths at all four corners? Could someone explain the benefits of keeping a staggered set-up? Thinking about rotating tires, I figured I'd be able to squeeze out a few more miles out of the tires since I'd be able to rotate all four corners instead of just side to side.
Would it change the handling and dynamic of the car's handling?
Thanks in advance,
Larry
TWELEVIE is offline   Reply With Quote
Old 04-07-2004, 12:10 AM   #2
BMW's, with 50/50 weight distribution, will always handle better with the same size all around. Your setup only promotes understeer.
I've seen people get away with mounting another set of 17x8.5's on 245/40/17's on the front without much issue. I'd stick with 235/40/17 all around though, nice balance.
Old 04-07-2004, 12:29 AM   #3
tlaselva
1800+ HP Driveway
tlaselva's Avatar
Send a message via MSN to tlaselva
^^ Agreed.
Staggered tire sizes are installed by care companies for asthetics.
Many people like the look of the larger tire in the rear. Looks sporty........
In the interest of performance, same sized tires all around are best. Helps neutralize understeer, which most BMW's are designed to do, in the interest of safety.
2011 X5 M-Sport 3.5i
2010 Dodge Ram Hemi Sport
2010 GSX-R 750
2003 C5 Z06
LS7 427CI w/ECS Novi 2000 : Caravaggio Widebody and Full Leather & Alcantra Interior
903rwhp/815rwtq : 10.3@152mph
tlaselva is offline   Reply With Quote
Old 04-07-2004, 04:37 AM   #4
sonny
sonny's Avatar
Go with these rims, they're awesome! (18'' OEM M Sport Package)
sonny is offline   Reply With Quote
Old 04-07-2004, 04:11 PM   #5
TWELEVIE
Would I be able to fit 8.5" widths all around?
Old 04-07-2004, 05:22 PM   #6
golden
Doesn't have a car.
golden's Avatar
wait, staggered setup is good for rwd cars cause youd want more grip in the back.. thats why drag cars have huge back tires
02' 325CI
golden is offline   Reply With Quote
Old 04-08-2004, 01:25 AM   #7
Sunapollo
definitely !! for the proper offset wheels
Sunapollo is offline   Reply With Quote
Old 04-08-2004, 01:43 AM   #8
WASABI
OG
BMWs aren't straight line cars though.
Old 04-08-2004, 06:02 AM   #9
STALKER
STALKER's Avatar
Send a message via MSN to STALKER
I would get staggered. I find they handle better, regardless of what some ppl say and plus you get a nice fat lip in the back.
2008 AW/FR E90 M3
//RAC RG63//Volk TE37//AP Racing BBK//Akrapovic Exhaust//Dinan SW//Dinan Intake//JRZ RS1 Coilovers//Dinan Monoball Control Arm Bearings//VRS Diffuser//
STALKER is offline   Reply With Quote
Old 04-08-2004, 08:05 AM   #10
SickFinga
SickFinga's Avatar
Originally posted by tlaselva
^^ Agreed.
would you switch to to 265 17" all around?
i dont think so
Old 04-08-2004, 04:46 PM   #11
golden
Doesn't have a car.
golden's Avatar
dont most ferraris havbe a staggered setup? i dont think its for aesthetics
its for handling and power off the line
02' 325CI
Old 04-08-2004, 10:00 PM   #12
SickFinga
SickFinga's Avatar
Golden, I dont there is a single performance RWD car without staggered setup.
Old 04-08-2004, 10:45 PM   #13
golden
Doesn't have a car.
golden's Avatar
i thought so
all you others guys are wrong
02' 325CI
Old 04-09-2004, 03:15 PM   #14
For mid-engine cars, they need the wider rear contact patch to handle the extra weight in the rear. Otherwise it would be oversteer city.
Cars with more than a certain amount of horsepower (like 375+ I'm talkin) require a wider rear tire to get the power down. The only reason the fronts result in being smaller is because such a wide front tire will produce heavy steering effort and may not even be feasible within the wheel well and fenders.
In any other car, it's just understeer-promoting, and for aesthetic purposes.
Case in point: the E36 M3. M50B30 models came with 17x8" 235/40/17 all around, and was the most neutral handling M3 ever made. BMW wanted to tame it down later, so what did they do? Retune the suspension for more understeer and install a staggered 225/245 setup. This is just plain worthless on a car with only 240hp. Really now, when are you having traction issues in your M3 or 330i? They can't even spin from a rolling start.
Old 04-09-2004, 03:15 PM   #15
