Old 05-29-2002, 03:58 PM   #1
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Weird Idle
Ocassionally when I have my car in neutral, Ill be sitting at a light and the idle will just drop to almost stalling then come back up, and keep doing it till i throw a few revs
I normally notice it beacause it does not feel like a bass note, I don't think it would be becuase of my subs because it does not draw that much and it does not happen all the time.
Im gettin the belts done on sat, Ill probably just get bimmersport to take a look, but knowing me and my luck it won't happen when hes around..
He will be the first real mechanic (other than the certification dude) too look at it in about 3 years..
Stanceiseverything.com
Old 05-29-2002, 06:13 PM   #2
Harry
2 Suggestions...
1. O2 sensor
2. Mass airflow meter.
Harry is offline   Reply With Quote
Old 05-29-2002, 06:20 PM   #3
e36m3
You should have a heavy-duty alternator installed if you're pulling a lot of current for your audio, also, how old is your battery? The best battery to buy is an M3 convertible-spec battery, especially if your car has stiffer springs than stock. That battery can take a lot more vibration than a stock-spec battery. You should be able to tell if there's issues with your charging system by turning on your foglights and rear window defrost at the same time. If you're drawing too much current, or your battery is getting old, which means it won't hold much backup capacity, then you'll definitely notice.
Power thrills. Absolute power thrills absolutely.
e36m3 is offline   Reply With Quote
Old 05-29-2002, 07:07 PM   #4
e36_freak
Mostly absent
e36_freak's Avatar
Send a message via ICQ to e36_freak Send a message via MSN to e36_freak
Originally posted by Harry
2 Suggestions...
1. O2 sensor
yah you should check these........is the most common reason why this happens
Life isn't about how many breaths you take, but the moments that takes your breath away.
Giving the government money and power is like giving a teenager whiskey and an M5.
[M]i[K]E[¥][M]i[K]E[¥]
e36_freak is offline   Reply With Quote
Old 05-29-2002, 07:08 PM   #5
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
my batts only like 3 months old, but I may check it because the first one I bought from crappy tire died in a day, this one may be wonky 2
I only have a 600w amp and a 140w dekc, I know people running more with no backup..
Old 05-30-2002, 02:09 AM   #6
Slowered318
mine bogs down when i click on my high beams and it's starting to tick just after i changed the oil.. hmmmm not good at all!
Old 05-30-2002, 02:51 AM   #7
Ahh....the idle problem once again!!!
Like Rob already said check the idle control valve! I seen that problem MANY times!!! 99% chances are the valve itself or even control module (green or blue box right next to the ECU). This problem is mostly noticable after highway driving. You can try to clean the valve, that can fix the problem or get it worst! New valve about $230! Used $50 to $75 but chances are IT WILL do it again very soon! I had like 10+ ETA's and they all did it at one point in time!
PS E36_freak WTF are you talking about??!!! didnt you see that problem like a 100 times and know what it is!!!!
Old 05-30-2002, 03:22 AM   #8
///Mr.T
///Mr.T's Avatar
Idle control valve. Mine did that for a while then it died completely! It died while I was sitting in brampton on queen trying to turn left with a pedestrian standing infront of me. The car revving to 3500 rpm and i couldnt do anything, I got the dirtiest looks! If it gets worse there are cheaper ways to fix... ask me how I know!
Axis Springs
HK2 Intake
500 watt Legacy amp
Two 10 inch JLA's in the trunk
///Mr.T is offline   Reply With Quote
Old 05-30-2002, 07:57 AM   #9
bimmersport
bimmersport's Avatar
I think in the first replies (Harry & e36_freak) didn't realize you had an E30...
I'll check it out for you on Saturday but like they said it's probably the idle valve or the idle control unit (VERY common problem on these cars!).
BIMMERSPORTAUTOMOTIVE
Specializing in BMW parts and service
905-670-9200
www.bimmersport.ca
bimmersport is offline   Reply With Quote
Old 05-30-2002, 09:57 PM   #10
Lil'Smoothie
Guest
Posts: n/a
I recently had the same problem except my car had alot of hesitation too. I thought it was my chip but I just found out I had a rip in a hose where air was leaking out, fixed the rip and she idles great again
Old 05-30-2002, 10:45 PM   #11
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
ya its not cool, cuz ppl are in the car and there like dude what the hells a matter with ur ride
well at least is a common problem..
bimmersport I can't wait to see ur reaction when u see my paint job
