Old 03-30-2004, 09:31 PM   #1
BMW_M52_M20
325E Hunting problems.......
Well, my idle is a bit irratic. It revs up and down about 200rpms. I have replaced the idle control valve and module, spark plugs, filters, cracked vacuum hoses/intake leak. I picked up a used (in very good condition) Air Flow Meter. I talked to someone with a similar problem, and they said it fixed the problem on there e30.
I am hoping this will work, just letting you guys know if anyone has experienced the same problem.
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 03-30-2004, 10:00 PM   #2
Acidblast
Acidblast's Avatar
i had the same problem when my car was idling. it was irratic. it took it to Charlie (bimmersport) and he replaced the Idle Control Valve and now its works perfectly.
"Ooh, they have the internet on computers now" Homer J. Simpson
Acidblast is offline   Reply With Quote
Old 03-30-2004, 10:06 PM   #3
M50E30
www.bmwclub.ca
M50E30's Avatar
Don't know if this is true but I heard that a CAI can possibly screw up the idle on an M20 engine. Has anyone else run into that situation???
Old 03-30-2004, 10:33 PM   #4
BMW_M52_M20
I thought about that but it has done ever since I have bought it which came with the stock airbox. When I put my new meter in I am putting the stock airbox back in, to avoid any problems in the future.
1986 325e (E30)
Old 03-30-2004, 11:21 PM   #5
BimmerKris
BimmerKris's Avatar
Re: 325E Hunting problems.......
It's probably the o2 sensor. It's a pain in the ass to change, but will feel like a new car when it is done.
www.eulogy.ca PURE CANADIAN METAL
BimmerKris is offline   Reply With Quote
Old 03-30-2004, 11:25 PM   #6
85eta
85eta's Avatar
Send a message via MSN to 85eta
Mine did that, there is a litle screw on top of the idle control valve. It's just a vacuum adjuster from what I know. Anyway, playing with that a little bit solved my problem.
85eta is offline   Reply With Quote
Old 03-30-2004, 11:31 PM   #7
John Hubbert
Stuck in 2nd Gear
John Hubbert's Avatar
Send a message via AIM to John Hubbert
My old 84 318i did the same thing ! played with the same screw cured it ...
Zexxy 325 iS
John Hubbert is offline   Reply With Quote
Old 03-30-2004, 11:53 PM   #8
BMW_M52_M20
Nope, not with mine, doesn't do anything to help. o2 sensor is a good idea, I will pull them out at work tomorrow.
1986 325e (E30)
Old 03-31-2004, 06:05 PM   #9
BMW_M52_M20
Well, I installed a new o2 sensor today. The old one was pooched big time so I am glad I replaced it. It didn't solve my hunting problem though
Oh well, got one option left on the list which is the maf, so I have bought a new one.
1986 325e (E30)
Old 03-31-2004, 10:12 PM   #10
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
my car did that adjust the icv
Stanceiseverything.com
Old 04-01-2004, 01:07 AM   #11
BMW_M52_M20
As I said before, I have aleady done that with no luck. I think it is either the butterfly flap is staying open a bit on either the throttle body or the air flow meter.
Ripping it apart this weekend.
1986 325e (E30)
Old 04-01-2004, 02:42 AM   #12
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Sorry, I didnt read all of it.
Good luck.
Old 04-01-2004, 02:47 AM   #13
ZiMMie
hmm i know get my IS Headers and My IS exhaust it will run perfect
#E36-S54 #CSLWannabe
Old 04-01-2004, 02:48 AM   #14
Probably intakes that aren't fitting tight, causing a vacuum leak. Everything from the AFM-back is stock, so it can't affect the idle.
Old 04-01-2004, 03:36 PM   #15
BMW_M52_M20
Yeah but if the AFM butterfly flap or the throttle body flap is not closing all the way, it could be causing the problem. I will check anyway this weekend, I am going to take the AFM out and throttle body and take the intake manifold off and polish it up.
1986 325e (E30)
