Old 03-29-2004, 01:21 AM   #1
SebSter
SebSter's Avatar
e30 maf box
after a long day with dan (felixthecat) trying to get my car up and running, we kinda got it to work but theres a bigtime air/fuel problem, so if anyones got a spare maf lying around that they could let me try swapping into my car to see if thats the problem id really appreciate it, and if its the fix id buy it off ur hands right away
or if anyone would like to lend a hand in at least diagnosing the problem, id hate to have to spend hundreds at a mechanic getting it fixed up..
anyways, lemme know if any of you have one lying around... thx
Seb
SebSter is offline   Reply With Quote
Old 03-29-2004, 01:28 AM   #2
windsor318is
Nitrous Junkie!
windsor318is's Avatar
heres a trick, seb turn you key to the on position without turning it over and press the gas pedal to the floor 5 times. the check engine light is going to flash in intervals and give you a 4 digit code, if you get 1215, then yes your maf is screwed up
Old 03-29-2004, 01:33 AM   #3
AFM guys, not MAF.
Old 03-29-2004, 02:45 AM   #4
felixthecat
Was touched by Micheal
felixthecat's Avatar
i tried that on his car...it didnt throw a code....
Old 03-29-2004, 02:47 AM   #5
windsor318is
Nitrous Junkie!
you didnt push the pedal all the way down then...
Old 03-29-2004, 02:47 AM   #6
Jase
twisted beyond reason
Jase's Avatar
I am assuming a 318 on will not work?If it does i have 2 you welcome to one
Old 03-29-2004, 02:51 AM   #7
felixthecat
hmmmm..im sure hes out in the driveway trying it right now....
if it is that seb i have a six cylinder one in the garage....im curious if the 318 one will work?????????
Old 03-29-2004, 06:03 AM   #8
SebSter
SebSter's Avatar
hey dan, thx for the call and letting meknow.. i wasnt at home i was out with my parents car for a bit...first thing in the morning im gonna try that, though my batterys dying now too.. after you left i turned off the car, then when i went to turn it back on batery died, had to boost it again
so im gonna see what code it gives and ill be back on here letting you guys know...i dont have a repair manual, so other than the code you gave me ill have no way of knowing what it means
thx for the help, hopefully someone will know if a 318 one fits cuz i have no idea either
Old 03-29-2004, 06:11 AM   #9
windsor318is
Nitrous Junkie!
seb ill find the link for all the code for you. jase i might be needing that from you..........
Old 03-29-2004, 06:12 AM   #10
SebSter
SebSter's Avatar
goodstuff thanks
Old 03-29-2004, 06:16 AM   #11
windsor318is
Nitrous Junkie!
here you go you have motronic 1.3
http://member.rivernet.com.au/btaylo...aultCodes.html
Old 03-29-2004, 02:18 PM   #12
SebSter
SebSter's Avatar
ok the code that came up is 1222 - lambda control 1
wtf is that?
Old 03-29-2004, 04:21 PM   #13
SebSter
SebSter's Avatar
hmm, and now no failures.. 1444
Old 03-29-2004, 04:28 PM   #14
R_JAY
Has the world for ransom
O2 sensor is on it's way out I think.
Old 03-29-2004, 04:33 PM   #15
SebSter
SebSter's Avatar
yeah somethings definately not working with the air/fuel mixture.... takes forever to get it to start, get a funny smell in the car.. i just dont wanna spend 300 on a new sensor and not have it be the problem
anyone have any ideas? its hard to explain the symptoms.. first, it takes about 3 tries to get it to start, then when its first starting up it coughs and sputters a bit till the rev finally raises to the 800-1000 level, theres a bit of a delay between when i press the gas and when the rev rises (i think that means that the mixture is lean if i remember correct), and i get a funky smell in the car
(ps, we changed the fuel pump yesterday, and fuel filter... before that it was impossible to even get it to start at all)
