Old 03-29-2004, 12:03 AM   #1
sirex
King Sirex
question about driving standard autmobiles.
my friend is under the impression that when he is driving if he puts the foot down on the gas, and gets to a great enough speed that he might as well just skip one of the gears.. for instance he will go from 2nd to 5th..
i see no benefit in this tactic.. he is under the impression that he is and I quote "[saving] gas"
now how can u save gas when your red lining in second and then changing to 5 th is out my mind, but anyway..
furthermore dont u put more straing on the gears?
any comments?
Old 03-29-2004, 12:12 AM   #2
///m powered
dodging pylons
///m powered's Avatar
Send a message via AIM to ///m powered Send a message via MSN to ///m powered
ya that doesnt sound good at all
i can get to around 45 - 50 ish in 2nd relining,, going to 5th from there would be unreasonable
///m powered is offline   Reply With Quote
Old 03-29-2004, 12:14 AM   #3
Jon@Bimmersport
Jon@Bimmersport's Avatar
why would u redline it in 2nd and go straight to 5th? he'd save more gas shifting at low RPMS going through the gears all the way to 5th...or jus going to the middle of 2nd, 3rd then to 5th.
Old 03-29-2004, 12:16 AM   #4
niko_gt
niko_gt's Avatar
your friend is stupid
niko_gt is offline   Reply With Quote
Old 03-29-2004, 12:21 AM   #5
sometimes i would go from 4K 3 straight to 5th., or 4K in 2nd, to 4th, but i dont think u save gas or anything....all ur doing is preserving the synchroes, by saving them once in a while
Old 03-29-2004, 12:25 AM   #6
Jon@Bimmersport
your saving the synchros each time u dont ram the gears...lol
it is jus easier and less work, if ur cruising, u dont go into 3rd and then 4th jus cuz its before 4th, jus go to the gear u need.
Old 03-29-2004, 02:08 AM   #7
King Luis
The King.
King Luis's Avatar
well said
Mods: TBD.
Sold:2004 Silver Gray M3
Gone:1990 Brilliantrot 325is
Old 03-29-2004, 02:15 AM   #8
M3ti Compact
Fuel Efficient 318 Member
M3ti Compact's Avatar
RPM's doesn't necessarily affect fuel consumption. It's more of throttle position that determines fuel consumption. My old Camry had a fuel consumption gauge, full throttle at low RPMS ate more than high RPM and little throttle.
Going from 2nd to 5th and full throttling will definitely waste more gas than 1/8 throttle going through all the gears
Old 03-29-2004, 02:39 AM   #9
BigD
the misanthropist
BigD's Avatar
Re: question about driving standard autmobiles.
Mathematically that doesn't make sense because you're achieving the same deltaV. But that's with a 100% efficient engine. Internal combustion engines are extremely inefficient, especially when working in our cars through a drive train - for every HP you produce, you waste almost as much (in a car it's probably MORE). So the less time you ask for your engine to work (force applied over a distance), the less energy you waste. So aside from the wear and tear on your engine and suspension, hauling ass up to a constant speed makes sense.
any comments?
Old 03-29-2004, 02:48 AM   #10
FastM3
is dreaming of ///M's
FastM3's Avatar
FastM3 is offline   Reply With Quote
Old 03-29-2004, 04:48 AM   #11
AMG_POWER
500HP Member
File Type: gif werd.gif (663 Bytes, 200 views)
AMG_POWER is offline   Reply With Quote
Old 03-29-2004, 05:15 AM   #12
A~G
Car Payment Free
A~G's Avatar
Send a message via MSN to A~G
Ur friends a dumbass. at 5th gear ur turning larger plates in the tranny so naturally u need more fuel to keep it turning . wasting "gas" is more like it.
correct me if i'm wrong. I prefer to be corrected and learn something than to continue thinking i'm right.. (Big D ... aka Mr. Physics )
A~G
Man who run in front of car get tired.
Man who run behind car get exhausted.
A~G is offline   Reply With Quote
Old 03-29-2004, 05:18 AM   #13
DAM
Trinational 951
DAM's Avatar
i do that, just dont' red line, or skip 2 gears, if i am driving conservativly and rev up to 4000, i will skip from 2nd to fourth. As long as you dont' put your foot to the floor after the shift, you are not straining the gears. I am not sure how much gas it actuall saves, but less shifts do mean longer clutch life.
You drive to work? I work to drive.
DAM is offline   Reply With Quote
Old 03-29-2004, 05:18 AM   #14
SickFinga
SickFinga's Avatar
Not exactly true.
In 5th gear doing 90km/h you are using way less gas than in 1st gear doing 20km/h
But you will waste way more gas doing 20km/h in 5th gear.
Being in higher gear at low speed puts a lot of stress to the engine - wasting more gas, oil and not very good for the engine life.
Sometimes i do 2nd o 4th when Im being lazy, but VERY rarely
Old 03-29-2004, 05:24 AM   #15
A~G
Car Payment Free
A~G's Avatar
Originally posted by SickFinga
Not exactly true.
thatz what i mean though.. if he goes from 1st to 5th, he's going what... like maybe 50km/h... when he puts it into 5th it takes alot of fuel to keep it rotating and bring it up to speed???right?no? maybe? i dunno?
A~G
