Welcome to!
Old 03-26-2004, 04:31 AM   #1
sUpeD Up BiMmEr
spacers and camber kit
hey guys i am going to be installing my bilsteins pss9s this weekend since the snow is finally not coming back and i was wondering if i am going to need a camber kit
i will be going as low as i can possible go without rubbing
also should i put spacers on my rims. they are 18s and stock rims but does it look better with spacers since they stick out wider
but come to think of it now with spacers and dropped it wont work ?? am i correct
2002 330ci - premium/sports/metallic paint/aerodynamics kit packages
Pirelli tires w/ ,18inch custom model 71 bmw rims,ACS pedal set inc dead footrest ,ACS shifter and Short shifter kit ,ACS E brake,ACS front badge, Bilstein pss 9 coilover kit , Kamei eyelids, Tint, Viper Pager Alarm , Custom intake, Red Calipers, shaved trunk and door keyholes,oem clears all around, piaa bulbs all around and interior.
sUpeD Up BiMmEr is offline   Reply With Quote
Old 03-26-2004, 04:43 AM   #2
thinair's Avatar
You more then likely won't need a camber kit. The mac strut suspension design on the front of your car won't really increase you camber much, even if you dump your car.
For the rear, if you really want to lower yor car you may need to get lower control arms. But install the coilovers, get an alignment first, and ask how far out of spec your camber is.
As for spacers, you might need them, depending on the offset of the wheel, and the width of the tires. My PSS's needed 5mm spacers even for stock wheels, but it's an E36, hopefully they fixed that problem with the e46's.
Also, if you run spacers without needing them, and lower your car, you're just pushing the wheels out giving them more of a chance to contact the fender lip with the tire.
Old 03-26-2004, 01:02 PM   #3
If you want to slam the back to have a even drop with the front, install the rear springs without the adjustable spring pearch. Lots of guys run the rear PSS/PSS9's without the pearch and it works fine. It all depends on how much you want to slam it. I run with the rear pearch but that's because I didn't want the rear to tuck.
Spacers depend on your wheel offset and what size tires you are running. It also helps alot if you roll the rear fenders. Install the PSS9's first, get alignment and then measure the space you have left in the wheel well.
2001 330ci / SP / HK / OEM Clears / OEM Eurotray / OEM M3 Steering Wheel / DIY Silvervisions
19" Hamann HM2's / 235/35ZR19 Yokohama AVS / ECIS CAI / JTD RSM / PSS9 Coilovers
M-Tech Package / PIAA Xtreme White fogs / 32% Tint / Zaino Polish / Umnitza Angel Eyes
EricE330ci is offline   Reply With Quote
