Old 03-16-2004, 06:47 PM   #1
kco325
Toe-in adjustment in rear wheels...
A recent accident bent my rear subframe (when someone drove into my quarter panel / rim) and when the alignment shop was trying to align it, they decided since it was lowered there was too much camber... so the guy said he notched out something in the subframe and filled something else in, so that toe-in could be adjusted in the rear, and camber would be reduced a bit closer to stock.
I don't entirely know what he did exactly because I haven't had a chance to get down there and drill him about it yet seeing as how he still has my car, but I think (read:hope) it ended up being a good thing.
On the bright side, they got me brand spankin new subframe bushings so that can't hurt (I wasn't looking foreward to changing those).
kco325 is offline   Reply With Quote
Old 03-16-2004, 08:22 PM   #2
BMW_M52_M20
Yeah, I was just going to say that sub frame bushings will fix that toe in, in the rear. Need to do the same with mine, especially since it is lowered.
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 03-17-2004, 12:32 AM   #3
BladeRunner
BladeRunner's Avatar
Good luck
Mad E30 lover
BladeRunner is offline   Reply With Quote
Old 03-21-2004, 01:48 AM   #4
kco325
I finally got my baby back. If I knew how to do smiley faces, I'd put down about 600. I've probably put on 3-400 km in the past two days that it was returned.
Here's an update for those who are interested; I talked to the alignment guy and what he did was he made new notches in the crossmember in order to mount the trailing arms differently, reducing the camber to a (more) reasonable amount. I definitely noticed less camber than my buddy's 325 (same as mine, same springs) but handling wise it's hard to compare (different tires, spaced much farther out on his).
Tire wear should be much better. It also allows for toe-in to be adjusted at any time for the rear wheels, which is apparently impossible stock. I don't know how he did this exactly, but I'm going to find out more.
Handling is great, I can't tell if that's because of the notching or because of the new back tires or what... but I would recommend it if anyone has their crossmembers out, because it only cost me 1 1/2 hours of work (75 bucks CDN) once the piece was off the car, and I think it'll save me more than that in tire wear.
Old 03-21-2004, 02:12 AM   #5
John Hubbert
Stuck in 2nd Gear
John Hubbert's Avatar
Send a message via AIM to John Hubbert
Thumbs up
Here is a good site that may help explain rear camber !
http://www.e30m3performance.com/inst..._sub/index.htm
Zexxy 325 iS
John Hubbert is offline   Reply With Quote
