Old 03-12-2004, 09:59 PM   #1
BiBimBap
BiBimBap's Avatar
Crisper Sound
Hey,
I know nothing about audio setups - NUTHIN! but I want to replace the stock speakers with something that's a bit more crisp - or defined.. I don't need super bass-kicking setups in the trunk (still need the space for crap)
I usually listen to everything between classical - to techno to metal...
I have a Alpine 9813 head unit.. now the million dollah question: What speakers and stuff should I be looking at?
BiBimBap is offline   Reply With Quote
Old 03-12-2004, 10:45 PM   #2
Jase
twisted beyond reason
Jase's Avatar
compont speakers for the front for sure( woofer and tweeter) it really depends on what your willing to spend. you can run 2 or 3 way 5 1/4 or 6 1/2 on the back
Old 03-12-2004, 10:47 PM   #3
beammer12000
beammer12000's Avatar
Send a message via MSN to beammer12000
the alpine type r's are good speakers but you should get the 5 1/4 inch component set. and for the rear the 5 1/4 inch coaxal alpine type r's speakers.
Your Nobody Unless You Drive A Bimmer
beammer12000 is offline   Reply With Quote
Old 03-12-2004, 10:53 PM   #4
Jase
Jase's Avatar
nice door setup. Are you glassing it in? or just doing a vinyl cover?
Old 03-13-2004, 12:47 AM   #5
I just installed those for my front stage. I've never heard better components.
Old 03-13-2004, 01:13 AM   #6
Lennon
Send a message via ICQ to Lennon Send a message via MSN to Lennon
Might as well match it for the rears then too, just get Type R's as well, I have them all around..... amazing sound, great for the price.
1990 735iL under construction.....
Lennon is offline   Reply With Quote
Old 03-13-2004, 03:02 AM   #7
BiBimBap
BiBimBap's Avatar
Wow.. awesome response. I was looking to keep it all Alpine too. I don't mind spending the cash if it's worth it. I played around with the Alpine website and it mentioned Type R 5 1/4s for the fronts and Type S for the rears.
Or is it pretty good for Type Rs all around?
Old 03-13-2004, 03:05 AM   #8
BiBimBap
BiBimBap's Avatar
Oh yeah, will I need to retrofit/custom mod anything for the door speakers to fit the 5 1/4s? I'm trying to keep things as stock looking as possible..
And the rears.. will 5 1/4s fit? I think the stock size is like 4"??
Old 03-13-2004, 03:20 AM   #9
Lennon
Well hey, if Alpine recommends that, then by all means give it a shot, I would just think that Type R's, being the bigger brother to the S's would sound a little better... but like you, I'm not the big audio knowitall, sorry, as far as fitment, I dunno the E36 sizes, I could tell ya the E30 sizes though!
Anyone else? Should he be puttin the type S's in the rear instead?
Old 03-13-2004, 03:41 AM   #10
BiBimBap
BiBimBap's Avatar
And while we're at it.. should i upgrade the wiring too? Or does stock wiring suffice?
Old 03-20-2004, 06:33 AM   #11
325phoenixbmr
I did type R 5.25 compenent up front...easy direct fit....and type-r 6x9's in the back...AMAZING....it'll almost sound like you have a sub without takin up your trunk. Its a hard install...(fiberglass old holes, cut new ones in speaker shelf and steel, reupholster) If you want I could send pics and how I did it...trust me though its totally worth it
325phoenixbmr is offline   Reply With Quote
Old 03-20-2004, 06:41 AM   #12
325phoenixbmr
The tricky thing about stock wiring is that e36 have three ways up front and most speaker systems are only two ways. if you just plug them in it would sound off you need to use the cross over that comes with the compenent set. To do that you'll have to use an amp, the preout of your deck, and custom wiring
The rear speakers are listed at 4" because they are tiny two ways built into a removeable speaker box. If you pop off the speaker cover take out the two screws the whole black box comes out from the trunk. I don't know what bmw was thinking using these tiny speakers in the back but buying something that will fit in there will probably leave you disappointed. You just can't get powerful sound out of such tiny speakers
Old 03-25-2004, 04:30 AM   #13
BiBimBap
BiBimBap's Avatar
So you're saying that the best output would be to remove the 'box' at the rear - cut out holes for 6x9's?
And while we're at it.. do component speakers fit the same way the coaxials fit? What's the difference?!
Old 03-28-2004, 07:02 AM   #14
BackSideWedgie
Send a message via AIM to BackSideWedgie
I have a set of type R's apline back and from 3 way.. I spent 310 canadian on them with 20 percent discount.. so ya I have the same head unit as well.. nice clear crisp sound man./
[img]
BackSideWedgie is offline   Reply With Quote
Old 04-06-2004, 03:21 AM   #15
LamBo
Send a message via ICQ to LamBo
MmmMmmm bibimbap....
Components sorta fit the same way in that the mid bass driver fits the same, but then u have to hide the crossover and figure out where to mount the separate tweeter,
putting them in a kick panel will give u best/good sound stage
if u have an apline deck, spend a lil and upgrade the wires, its allworth it
Giggle giggle janggle
These chicks dont even know the name of my band.....My band my band my band
LamBo is offline   Reply With Quote
