Old 03-13-2004, 01:10 AM   #16
John Hubbert
Stuck in 2nd Gear
John Hubbert's Avatar
Send a message via AIM to John Hubbert
Smile
Allright then ,looks like I'm goin with the plastic ones too Al . At that price you can do a new set every year or so , I have heard that the heat and what not causes them to crack , how have you found them ?
John Hubbert is offline   Reply With Quote
Old 03-13-2004, 01:19 AM   #17
windsor318is
Nitrous Junkie!
windsor318is's Avatar
so fa so good john, i had a set of them on my previous rims as well for 3 years also with no problems, if you dont have them right know with the new rims i highly suggest you dont drive without them, its very unsafe and theres no way they run true if its just centered right know with the bolts.
eh john, i notice you attach a pic on your posts, if you right click on the image you posted click on properties and it will tell you the location of the pic. then go into your user cp and plug that location in the signature box with..
[ img ] at the front and [ /img ] at the back of it with no spaces in between
hope this helps, you wont have to attach a pic every time
Old 03-13-2004, 01:31 AM   #18
John Hubbert
Stuck in 2nd Gear
Thank's Al I'll give that a try , I was going to wait till I had a killer sig but I'll give it a go !
Old 03-14-2004, 03:07 AM   #19
John Hubbert
Stuck in 2nd Gear
Smile Thanks Al
It only took about 10 try's but I finally got it , Thanks Al .
Now who do I got to blow , I mean Know to get one of those Avitar things ?
Zexxy 325 iS
Old 03-14-2004, 03:50 AM   #20
felixthecat
Was touched by Micheal
felixthecat's Avatar
the 300 post fairy will hook you up john...
Old 03-14-2004, 02:22 PM   #21
John Hubbert
Stuck in 2nd Gear
Talking
300 fukin posts , How did you get to that in just a couple of months, do you stay up all night postin ?
Zexxy 325 iS
Old 03-14-2004, 05:57 PM   #22
felixthecat
i did over 300 post in my first month john.....mostly argueing with other ppl...
Old 03-15-2004, 01:51 AM   #23
DanPinder
The reason he can't run large spacers and you can is because of his lack of negative camber.
I ran 18" 42mm wheels with 1" spacers and A LOT of negative camber with no problems.
The width of the wheel comes into account here also.
I just purchased some 19" wheels, so we will se how that goes. I believe I may actually need to raise the spring cup when I install my front coil overs and then install a shorter spring.
DanPinder is offline   Reply With Quote
Old 03-15-2004, 01:58 AM   #24
windsor318is
Nitrous Junkie!
pics as soon as you have the 19's on PLEASE!!!!!
Old 03-15-2004, 02:06 AM   #25
John Hubbert
Stuck in 2nd Gear
Wow an E-30 with 19s , can't wait to see that ...
Thanks to Al for the help with my sig !
Zexxy 325 iS
Old 03-15-2004, 02:07 AM   #26
windsor318is
Nitrous Junkie!
nooooo problem john
