03-11-2004, 12:19 AM
#1
Nitrous Junkie!
Car: 91 e30 318is,96 328is
anyone interested in....
well im kind of slow at work and i was wondering if anyone would be interested if i were to make a few adaptors for a K&N induction filter that is required to make fit onto the mass air flow????? i have purchased the kit from bav auto so i can just duplicate mine, should fit the same for 325 engines as well.
the cnc machining legend Al.
03-11-2004, 12:21 AM
#2
Car: S54/E36
make as much as u can if noone is intrested u can always sell them on ebay...
03-11-2004, 12:24 AM
#3
Nitrous Junkie!
i could but then id have to sell it all together with the k$n, you guys are smart enough to just go buy one from crappy tire
03-11-2004, 12:30 AM
#4
Mr. Euro E30
Car: 1993 BMW 320i (sold), 1989 BMW 325is
can you make wheel adapter ? 4x100 to 5x130 ?
03-11-2004, 01:08 AM
#5
Nitrous Junkie!
fuk that, that will take to long and be to expensive!!!!
any realistic requests??
03-11-2004, 01:59 AM
#6
Crazy Canuck
Car: '91 325is
how bout 4x100
10mm spacers?
03-11-2004, 02:02 AM
#7
www.bmwclub.ca
Car: '02 Accord
empowerd asked about those spacers for my E30 when he went to the Essen Motor Show in Germany. The minamum thickness is 40mm and blody expensive.
03-11-2004, 02:48 AM
#8
Mr. Euro E30
M50E30: i read in some forum, min. is 20 mm 4x100 - 5x130, based on the seller that made them
03-11-2004, 03:01 AM
#9
R/C JUNKIE
Car: 1986 bmw 325
id be interested in the afm adapter, how much is it gonna cost and were u located, beacuse my driving range is limited to gta area
03-11-2004, 08:49 AM
#10
www.bmwclub.ca
Car: '02 Accord
Even 20mm is too thick for E30's. My ADR wheels (18" X 7.5" w/ a 42mm offset) with 20mm spacers all around were too big. I think that a 12mm spacer in the front and a 15mm in the rear would have worked perfect for me.
Dave
03-11-2004, 09:11 PM
#11
Nitrous Junkie!
Dave
huh??? my 18x 7.5 have either a 42 or 45mm offset and im running a 25mm spacer no problem with the rear fenders rolled
djtbster, not sure on price yet, ill give you a price once ive finished one of them, im in windsor put i come down often
03-11-2004, 09:34 PM
#12
www.bmwclub.ca
Car: '02 Accord
My wheels are +42mm offset. I used a 20mm spacer and they rubbed. Look at my front fender (pic below)...sucker got pulled down under turning and hitting a bump at the same time. And the rears rubbed very slightly on the upper part of the inner fender.
03-11-2004, 09:37 PM
#13
Nitrous Junkie!
he he, dave my front fender lip bent just like that too, the fender roller doesnt work on the front when i rolled the backs, but a rubber hammer did the trick!!
did you roll the back at all??
03-11-2004, 11:02 PM
#14
Stuck in 2nd Gear
Car: 1987 325is
Hey Al , hows thing's . Can you make the little hub centric things,
most of them are plastic rings , but I heard that a tire place in concord makes them out of Aluminum ... Do you run them on your car, or are they built on your spacer's ? I know the hub is 57.1 mm, and I think the wheel is 2.9 inches , what ever that is in mm .
Let me know if it's somthin you would like to do or not ! Time and material , let me know or what ever . Thank's John .
03-12-2004, 04:00 AM
#15
Nitrous Junkie!
johnny, i was already thinking of this but theres no advantage to makeing them outa aluminum or steel compared to the plastic ones, and theres no way i can make a set of 4, for less than 9 bucks, which is what i payed for the ones i have.
