Old 03-09-2004, 09:38 PM   #1
bmdoubleya
bmdoubleya's Avatar
Clutch feels very soft???
Just took the car out for its first drive in 4 months. About 2 weeks after I stored the car the clutch went just droped to the floor like the slave cyl was broken.....Now it works fine but feels a little spongie?? any ideas Thanks
bmdoubleya is offline   Reply With Quote
Old 03-10-2004, 08:01 AM   #2
crazyvadim
crazyvadim's Avatar
Re: Clutch feels very soft???
See if theres enough fluid in the reservoir,you might have a leak.You might also have air inside the system,try bleeding it.....there should be a bleeder screw on the slave cylinder.
Old 03-10-2004, 03:45 PM   #3
chromius
chromius's Avatar
Not positive, but you could check under the dash at the adjustment spring, if this is not adjusted properly it might feel loose or spongy....you could try and tighten it up. just a thought.
Old 03-10-2004, 10:43 PM   #4
bmdoubleya
bmdoubleya's Avatar
Thanks guys I will check both
