Old 03-05-2004, 11:19 PM   #1
Skimeister
Send a message via ICQ to Skimeister Send a message via AIM to Skimeister
Question Help...removing instrument cluster.
Hey guys.... I need to remove my instrument cluster (speedo, tach unit). How hard is it ?? do I need to remove the enire dash ? Can someone please give me some instructions... thanks !
Skimeister is offline   Reply With Quote
Old 03-05-2004, 11:32 PM   #2
nzer
nzer's Avatar
Remove the steering wheel (its just easier). Remove the trim that goes down to your legs by the pedal and is under the dash. There are two big screws that you can undo with your hand by reaching up inside and underneath the dash and then the front big of trim by the steering column comes off. Its pretty obvious now - unscrew the trim round the instrument cluster - unscrew the instrument cluster and pull it out.
good luck
BMWs Downunder
http://www.bimmersport.co.nz
nzer is offline   Reply With Quote
Old 03-06-2004, 12:37 AM   #3
BladeRunner
BladeRunner's Avatar
to remove the steering wheel you'll need a 23mm socket to remove the bolt located beneath the roundel in the center of your steering wheel. Pull hte intrument cluster out by grapping hte tabs and lowering them just enough to carefully wiggle the cluster out. Not sure how many wires you have behind your cluster but just incase you don't have a photographic memory it would be best to label all the wires connecting to the cluster.
I used a knife to remove many of my clusters because the flat head of most screw drivers are to thick to wedge between points. The cluster can be easily removed with the steering wheel still in, only problem is that some manuevering is neccessary to get to some screws.
It's a 1+hr operation if you don't know what your doing and are careful.
Go here for some instrustions: http://www.strictlyeta.net/technical/dashboard.html
Mad E30 lover
BladeRunner is offline   Reply With Quote
Old 03-06-2004, 01:26 AM   #4
snd84318i
snd84318i's Avatar
i didnt do that to remove it . all you need to do is unscrew two nuts behind the bottom of the dash unit then that little cover comes off then just unscrew two silver screws on top into the dash near the clear cover then unscrew some black screws behind that plastic cover you took over and fiddle it out good luck
snd84318i is offline   Reply With Quote
Old 03-06-2004, 04:25 AM   #5
Skimeister
Thanks guys ! I'll try to tackle it this weekend...either way I'm relieved that I don't have to remove the entire dash. Cheers !!
Old 03-06-2004, 08:58 PM   #6
nzer
nzer's Avatar
It only takes 10 - 20 mins tops. Easy job.
BMWs Downunder
Old 03-06-2004, 09:49 PM   #7
NickP
NickP's Avatar
This is my favourite write up on this how to:
http://www.e30m3performance.com/main...d/SI_Board.htm
Old 03-06-2004, 10:02 PM   #8
jeremy
you don't have to take the wheel or dash off...
-remove kick panel
-reach up behind the kick panel. there are to thumb srews you need to remove that hold in a trim panel
-re-move gauge cluster trim
-un-screw screws holding in the cluster ears.
-un plug cluster.
i have done this toooooo many times...it is a fairly easy task.
Old 03-09-2004, 07:24 PM   #9
BladeRunner
what was your reson for removal?
PS excuse my link NickP's was better
Mad E30 lover
