Old 03-05-2004, 04:52 PM   #1
objec
Send a message via AIM to objec
oil pressure switch, turbo oil line
anyone have a pic of their oil pressure switch with oil feed line for a turbo, i need to know where to get oil for a turbo, will i have to drill buy the oil pressure switch, how do i attach the line?
objec is offline   Reply With Quote
Old 03-05-2004, 07:01 PM   #2
NickP
NickP's Avatar
You can buy a "Tee" - no drilling required... you'll just have to figure out the thread size / pitch of the oil pressure sensor.
This is what I'm doing turbocharging my winter beater
Old 03-05-2004, 11:35 PM   #3
nzer
nzer's Avatar
I think your getting mixed up - your going to have to tap the pan for the oil return from the turbo.
You can use a T connector off the oil pressure switch mount - one for the oil pressure switch and one for the turbo - don't forget to restrict the oil pressure to the turbo - 25ish psi will be good and just bathe the turbo in oil - not spray it on.
BMWs Downunder
http://www.bimmersport.co.nz
nzer is offline   Reply With Quote
Old 03-06-2004, 03:39 AM   #4
objec
where is the oil pressure switch located on and 97 325e
Old 03-06-2004, 08:59 PM   #5
nzer
nzer's Avatar
I asume you mean an 87 eta -
I have an m20b20 and its located on the bottom of the block - can't really miss it.
BMWs Downunder
Old 03-06-2004, 09:41 PM   #6
NickP
NickP's Avatar
I haven't heard of anyone restricting pressure in the oil feed line... got more info on that one?
For the return line you can go with drilling the oil pan or if you have an i motor you can take advantage of the oil return line from the oil cooler.
Old 03-09-2004, 07:55 AM   #7
nzer
nzer's Avatar
The oil pressure is reasonably high in the car - if you spray oil onto the turbo - its not going to be happy. It wants to be bathed in it. I can try find some articles for you.
BMWs Downunder
Old 03-11-2004, 02:23 AM   #8
objec
still cant find it
Old 03-12-2004, 02:28 AM   #9
nzer
nzer's Avatar
Originally posted by objec
still cant find it
you have to be joking..
BMWs Downunder
