Welcome to!
Old 03-03-2004, 09:10 AM   #1
Results with offset m3 CA bushings?
While under my car the other day, I decided to finally do something about those damned cracked bushings that I always have to look at.
It looks like my main problems are CA bushings and swaybar bushings, but I was curious if anyone has had problems with the increased caster on the m3 bushings, and if people usually go for Poly, or just oem bushings?
kco325 is offline   Reply With Quote
Old 03-03-2004, 09:00 PM   #2
i am waiting to do this, i was going to go with poly and aluminum control arms for the m3, they are supposed to be bolt in place of the steel ones and are fairly cheap ($175/each). they say that by using the m3 bushings that you will have increased stability at higher speed than with the stock ones. i was going to use poly because i am not going to do the job again later (do it right the first time), plus the rigidness of the poly will help with handling. the only thing is i was also wondering if the increased caster will adversly affect my car being lowered 2.5 inches, i think that it would help out but i dont specialize in suspensions.
BMW--Because Mine Won
