Old 03-03-2004, 04:22 AM   #1
djtbster
R/C JUNKIE
djtbster's Avatar
Send a message via MSN to djtbster
ICV issue
hey i got his damn icv (idle control valve) issue and still dont know how to tackle the problem, ane remedies to this problems, thanx in advance
djtbster is offline   Reply With Quote
Old 03-03-2004, 04:43 AM   #2
snd84318i
snd84318i's Avatar
does it idle to high about 1500 to 2000 rpms if thats what your talking about i turned the screw in it and brought it down to 1100 rpms . i still need to get new one but it works for now
snd84318i is offline   Reply With Quote
Old 03-03-2004, 05:51 AM   #3
Jase
twisted beyond reason
Jase's Avatar
if the car idles up fopr no reason try to clean it if that does not work than your in for another one
Old 03-03-2004, 08:39 AM   #4
crazyvadim
crazyvadim's Avatar
Most likely theres blockage in the passge of the IACV.You can check the valve by jumping the battery voltage to the windings,that should trigger the solenoid and change the engine speed,if the engine speed doesnt change then just check for blockage before you replace the ICV.
Old 03-03-2004, 08:49 AM   #5
Sometimes the problem is in the idle control valve module, right next to the main computer. If you put a new ICV and it still has the problem, then check the module...I have a few of them for sale...
