02-28-2004, 01:51 PM
#1
Car: 97 328is
supersprint exhaust needs repair
of all the mods i've done (not many really) - my supersprint cat-back exhaust was well worth the money.... now after 2 maybe 3 years it's got a hole (approx. 1" dia)...
i need to take it to a muffler shop to see if it can be repaired properly... any shops in the west end (miss / brampton) that will do a good clean job??
02-28-2004, 02:07 PM
#2
Car: 97 328is
some pics
it's bigger than i thought... more like 3" x 1"
#3
BMW Traitor
Car: AMG, M, R, Aero
Doesn't SS have a lifetime warranty?
'02 Mercedes C32 AMG 3.2L Supercharged @ 18psi - 341WHP/358lbs*ft TRQ (DynaPak) Eurocharged custom tune, ASP 178mm crank pulley + PSK, CM30 i/c pump, i/c iso kit, Magnecore wires, NW CAI, dual custom exhaust, H&R sway bars, H&R SS coilovers, KMAC camber kit, H&R spacers, Quaife ATB LSD, goodridge SS lines, Porterfield RS4 pads, AMG 18" rims, AEM UEGO wideband, Dashdaq datalogger, Kenwood Excelon DNX8120
#4
Car: 97 328is
just for fun
02-28-2004, 02:53 PM
#5
Car: 97 328is
i'm pretty sure it's 3 years (maybe the stainless steel parts come w/ lifetime warranty?)
i looked into my files - i bought it in Sept 2000... 3 1/2 years ago
02-28-2004, 09:45 PM
#6
whooop whooop
Car: ...
i have the same exhaust, with the same problem.. mine is less than your.. it's just under the "serial number? " plate.. a little piece of metal 2-3cm by 5-6cm..
look like it's the same place as your..
02-28-2004, 10:58 PM
#7
moderationistismingly
Car: 97 328is-02 Impreza
Does Supersprint make non-stainless exist exhausts? Stainless steel doesn't rust right?
02-28-2004, 11:11 PM
#8
Car: H ACC
cant u just patch up the hole with metal and weld it ?
02-28-2004, 11:42 PM
#9
Car: 96 328is
same problem here! mine is rusting, but theres no hole yet. it wont last long, i give it a year and a hole opens. i also would like to know if it can be patched up
02-29-2004, 12:01 AM
#10
OG
Car: N55 E92 MSport
The only stainless steel SuperSprint made for the e36 was for the M3, which still fit non-M.
When my brother's car was towed, the towing company scraped his exhaust so bad that it put a hole on it, it was the size of a toonie. The body shop patched it up with a 3" square of stainless steel, his muffer is stainless steel.
That hole looks pretty big though. It's probably doable, but it'll probably rust again. Take it to a muffler shop, they can probably grind off all the rust to expose bare metal so they weld on it. You'd have to see if it's worth all the trouble though.
02-29-2004, 02:23 PM
#11
Car: 97 328is
i took my car to a Midas near my house... first the guy's like "Looks like you need a new muffler"
A**hole... how bout fixing it i ask - "Oh yeah you can do that too"
40 bucks to weld a plate to it and it should perform as intented before it eventually breaks again
i didn't go through the details right then and there but i need to determine what type of material to use (i.e., can i use galvanized steel... satin finish... or something similar to offer a level of rust resistant.... i'm pretty sure welding a stainless plate won't be an option
02-29-2004, 03:32 PM
#12
BMW Traitor
Mine is an ANSA and I'm starting to see some surface rust at the bottom. There's nothing you can do about it, the extreme heat really wears down the metal. It seems like the cheap aluminized mufflers from Magnaflow last longer than our Italian made exhaust systems. Oh well, please let us know how the exhaust system works out after you have the plate welded in. I'd be interested to know since I may be doing this soon someday. (fingers crossed)
Bry
08-26-2004, 03:00 PM
#13
Car: 97 328is
[Oh well, please let us know how the exhaust system works out after you have the plate welded in. I'd be interested to know since I may be doing this soon someday. (fingers crossed)
Bry [/b][/quote]
OK here's the update (better late than never)
the hole was patched up by mig welding a plate over it and painting it w/ heat resistant muffler junk
it's been about 8000 kms and still looks good... sounds much better but it's still noticeable when i'm at a stand still
worth the effort
For Sale - OEM Rear Spoiler (E36) painted Jet Black - $100... pics available - send me a PM if interested
08-26-2004, 06:29 PM
#14
Car: 87 e30
stainless doesent usually rust... but it will rust around welds and if u give it alot of heat it might rust
08-27-2004, 04:31 PM
#15
Who's your daddy now?
Car: 96 BMW 318i/M3S/C bondmobile on NOS with rocket launchers
Too bad you guys don't live near Windsor. I can tig weld a stainless steel patch no problem. Done it many times and only takes 20 minutes.
