Old 02-09-2004, 09:42 PM   #1
sjinto
Question it's getting cold... heater problem
my heater display has been sporadically shutting off and on.... the heater konks out whenever the display does... today it went off on my trip from brampton to downton t.o. BRRRR!.... no problems on the way back though?
any ideas on what it could be and what i should look for?
sjinto is offline   Reply With Quote
Old 02-10-2004, 02:11 PM   #2
djcontra
Gets Blown Daily
djcontra's Avatar
is it the heater that shuts off or the fan? does it work on the highest setting only? If so, then there is a resistor behind the control unit that has gone bad (common problem on e36).
If it's not that, then perhaps the control unit has a loose connection, or might be going bad. Let's just hope there's something loose and you can get it fixed fairly easily.
Also, if your windows are fogging up, or have an oily film on them, then your heater core is pooched.
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
Old 02-10-2004, 06:25 PM   #3
sjinto
thanks for the direction... i guess i can rule out the resistor problem as the heater doesn't work on the highest setting.... i'm hoping it's just a loose connection but i doubt it.... my ride is running close to 200,000 km... i guess it's time the "fun" begins
Old 02-10-2004, 08:22 PM   #4
Turkish
Turkish's Avatar
Send a message via Yahoo to Turkish
sounds like you need to pull it out and have sniff around behind the switch mate!
Join my new site now!
www.bmwz.co.uk
Turkish is offline   Reply With Quote
Old 02-11-2004, 03:11 AM   #5
JDub
The same thing happened to me on the weekend. I turned on my heater and the display dimmed down. Came back on and then shut off. I was on my way to my mechanic when this happened so I got him to check it. It was my thermostat so I got it replaced and so far it's been ok.
97 328i SOLD
04 330Ci
JDub is offline   Reply With Quote
Old 02-12-2004, 04:24 AM   #6
Alwysfresh
Registered User
Alwysfresh's Avatar
If the display is turning on and off on it's own it's probably heater control unit...same thing happened to me when I first bought my car. It's a pretty common problem on these things. I thought it happened again a few months ago so I got my old one rebuilt, but it turned out to be the final stage unit (the display stayed on this time, but the fan had a mind of its own). My bet is that it's one of the two. I'm trying to get rid of the rebuilt unit I have sitting here if you're interested...I'm in Mississauga if you want to drop by we can try it out to see if it fixes your problem. I paid $220 to get it rebuilt, so we can work out a better price than that. They're over $400 new from the dealer. Let me know (cell is 416-803-5725 if it's easier).
Alwysfresh is offline   Reply With Quote
Old 02-21-2004, 04:01 PM   #7
sjinto
thanks for the advice guys....i'll have the thermostat checked out first... if my mechanic suggests there may be an issue with the control unit - i'll be in touch
Old 02-23-2004, 02:34 PM   #8
sjinto
who's your mechanic?..
Old 02-25-2004, 06:36 PM   #9
sjinto
djcontra.... i read in one of your posts that you had your bad final stage resistor repaired...
where can i get that done?... i'm pretty sure that's the problem - the dealer sells a new resistor for $127 parts only
thanks for your help bro
[QUOTE]Originally posted by djcontra
[/QUOTE
Old 02-25-2004, 08:21 PM   #10
4life
4life's Avatar
My blower was not working on mine a few weeks ago. The display was fine but no heat at any fan speed, tested some circuits and it turned out to be the final stage unit, took me about 1 hour to replace.
for the guy who's display dimmed and then his mechanic changed the thermostat, who is your mechanic, so that I NEVER bring my car there!!!!
4life is offline   Reply With Quote
Old 02-25-2004, 11:57 PM   #11
djcontra
Gets Blown Daily
djcontra's Avatar
sjinto: I sent you a pm
Mods
-Shortstack headers
-Vortech RRFPR
-Remus full catback
-SMT6 EMS (Untuned)
Old 02-26-2004, 01:15 AM   #12
sjinto
got it
Old 02-27-2004, 02:20 PM   #13
JDub
Well, I knew I had to get the thermostat fixed since my engine temp guage wasn't going to the middle and that was the source of my heater not working. NO problems since.
97 328i SOLD
04 330Ci
