Old 02-24-2004, 12:31 AM   #1
King Luis
The King.
King Luis's Avatar
prices needed
my friend just bought a 86 325is and he needs some prices and information. here is the list:
1. cost of front and rear bumpers. 91 style or m-tech I or II
2. how much for:
-window seals
-trunk seals
-steering wheel
-shifter knob
-intake
-exhaust
-kph guages for speedo and fuel economy
-antenna and seal for it.
-1986 bmw 325is manual
3. passenger window doesn't open???what can it be...no noise when button is pressed.
4. driver door lock doesn't work. it won't unlock or lock. can't even push the door lock to lock it??what can it be???
5. gears sometime grind even with clutch in all the way.
that should be it for now
thanks
Mods: TBD.
Sold:2004 Silver Gray M3
Gone:1990 Brilliantrot 325is
Old 02-24-2004, 01:03 AM   #2
qimis
Mr. Euro E30
qimis's Avatar
my driver side window doesn't open either when the weather is cold i think it got frozen after i washed the car.
dont force it though, you might break those plastic inside.
qimis is offline   Reply With Quote
Old 02-24-2004, 01:12 AM   #3
King Luis
The King.
King Luis's Avatar
it's power windows
when i press the button nothing happens
also there is a button beside the defrost that is black and red
what is it???and a dial beside the hazards button what is that??
-what is the normal redline on a 86 325is???
and the temp guage isn't working???
anyone have ideas on anything???
Mods: TBD.
Old 02-24-2004, 01:17 AM   #4
qimis
Mr. Euro E30
qimis's Avatar
yup, mine's power window too and same problem. try to wait until the weather gets warm abit and try again.
hmm ... mine only have the rear window defroster and hazard light
Old 02-24-2004, 02:42 AM   #5
King Luis
The King.
King Luis's Avatar
ok thanks
can anyone help me on the other stuff???
Mods: TBD.
Old 02-24-2004, 03:00 AM   #6
beammer12000
beammer12000's Avatar
Send a message via MSN to beammer12000
take the door panel off and check to see if power is going to the motor if no power then you need a switch. for the tem gauge replace the coolant temp sensor that should help. for the door lock with the panel already off check and see if the links are bent or if anything is in the way.
Your Nobody Unless You Drive A Bimmer
beammer12000 is offline   Reply With Quote
Old 02-24-2004, 03:33 AM   #7
gsbadbmr
There is NO such thing as a 1986 325is. The 325is started in 1987.
-gsbadbmr
gsbadbmr is offline   Reply With Quote
Old 02-24-2004, 03:38 AM   #8
ROBM3
ROBM3's Avatar
Send a message via ICQ to ROBM3
There is no such thing as a "1986 325is"
In '86 it was called the 'es' (127hp, sport suspension)
In 1987 it was called the 'is' (168hp)
ROBM3 is offline   Reply With Quote
Old 02-24-2004, 03:57 AM   #9
felixthecat
Was touched by Micheal
felixthecat's Avatar
2. how much for:
-window seals (got them)
-trunk seals(got one)
-steering wheel
-shifter knob(got one)
-intake
-exhaust
-kph guages for speedo and fuel economy(got a whole cluster)
-1986 bmw 325is manual(88is)
3. passenger window doesn't open???what can it be...no noise when button is pressed.(got the window or the switches)
pm me your number i'll give it all to him cheap..
Old 02-24-2004, 04:04 AM   #10
BMWE30
Send a message via AIM to BMWE30
The switches your referring to on the dash...the knob with the 2 speaker figures on it is the stereo fader switch. The black and red push button with the arrow on it is the power window circuit breaker. An 86 325is? Dont exist man, at least in US anyway.
Vincent Esser
1987 325 2 door
Too many mods to list
BMWE30 is offline   Reply With Quote
Old 02-24-2004, 04:15 AM   #11
lvan
lvan's Avatar
my windows open on -25 haha but my rear left lock does not pop up when i unlock my central locking system. I can pop up the lil panek and unlock it from inide but I want all four 4 to unlock at once. Any know the problem?
Old 02-24-2004, 04:16 AM   #12
King Luis
The King.
King Luis's Avatar
the car is from BC
the person who sold it said 1986 325is. maybe she meant i
here is a pic
Mods: TBD.
Old 02-24-2004, 04:54 AM   #13
lvan
lvan's Avatar
awww that bimmer is PIMP
Old 02-24-2004, 02:12 PM   #14
chromius
chromius's Avatar
The easiest way to check what year it is, is to check the VIN on the car, the 10th spot will have a letter from A-M but NOT including "I", where A=1980 B=1981 etc.... M=1991....you get the point...so check that... ex. WBA AA13 1 - L A E57862 This vin is an L (count the dash) ie 1990.
As for you're windows I have had both my front window switches go, its a common wear item...50 bucks to replace if you DIY, and my passenger one was the first to go.
And that car is definitly an "is" cuz its 2 door, but check the VIN for the year.
Old 02-28-2004, 01:29 AM   #15
qimis
Mr. Euro E30
qimis's Avatar
i just figured out this today if your driver side window wont open, try to open the passenger side a little and close it again, then try the driver side it works on mine !
