Old 02-23-2004, 06:18 PM   #1
hammoj28
4 Exhausts, please help !!
I have seen some E30's with an mtech 2 kit like mine and four exhausts (twins at each side). So, I had a look and sure enough it would be easy enough to cut another hole in the kit but there is a problem. The underneath of the boot gets in the way and I can't see space for another set of twin exhausts let alone the box. Does anyone know what to do ?
hammoj28 is offline   Reply With Quote
Old 02-23-2004, 06:39 PM   #2
beammer12000
beammer12000's Avatar
Send a message via MSN to beammer12000
to get the other side to fit you have to cut out the battery box thats the only way you are going to fit the muffler on that side.
Your Nobody Unless You Drive A Bimmer
beammer12000 is offline   Reply With Quote
Old 02-23-2004, 06:48 PM   #3
hammoj28
Thanks but what should I do to cut out the battery box and should I use fibreglass t cover it up?
Old 02-23-2004, 06:48 PM   #4
Euro_E30
Euro_E30's Avatar
some people cut out the spare tire compartment and weld a peice of metal to cover the big hole and run the muffler right under there i've seen it before and it works great.
Euro_E30 is offline   Reply With Quote
Old 02-23-2004, 06:53 PM   #5
hammoj28
I forgot to ask, what gives the exhaust a really deep sound, is it wider pipes or what?
Old 02-23-2004, 06:56 PM   #6
beammer12000
use a grinder to cut the box out . then with fiberglass out metal cover it back up. for deep sound it depends on the exhaust muffler. remus is a good one the bigger pipe only give more flow.
Old 02-23-2004, 06:59 PM   #7
hammoj28
I'm probably going with powerflow exhausts because they are near me and they build fully customised systems.
Old 02-23-2004, 09:08 PM   #8
beammer12000
thats your best bet give them the head eches
Old 02-23-2004, 10:02 PM   #9
qimis
Mr. Euro E30
qimis's Avatar
Re: 4 Exhausts, please help !!
got more (and bigger) pics of that car ?
qimis is offline   Reply With Quote
Old 02-23-2004, 10:12 PM   #10
hammoj28
Unfortunately no, it was a feature car in performance BMW magazine. It is an E30 325i with a turbo and it produces 350bhp !!. The issue is November 2003. Try and order a back issue or go to their website :www.performancebmwmag.com . If that doesn't work I will try and scan some more pictures of it from my copy sometime.
Old 02-23-2004, 10:54 PM   #11
Jase
twisted beyond reason
Jase's Avatar
Since the exhaust is dual on a 325. couldnt you split it after the cat and go straight back?My car has the battery under the hood on the passenger side. Could you just put the battery back up there?
Old 02-24-2004, 01:51 AM   #12
BladeRunner
BladeRunner's Avatar
i wondering the same thing but then i saw that his sig reads 3.0 transplant so maybe there was no more room for a battery upfront? me too. a while back someone posted a bmw with four exhaust setup. may this will help you a little
Mad E30 lover
BladeRunner is offline   Reply With Quote
Old 02-24-2004, 05:28 AM   #13
dansciol
Send a message via AIM to dansciol
Here's an exhaust I found on ebay last week. Not the greatest design, but it would work.
Personally I don't see any benefit to it, even aesthetically.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2460697279
dansciol is offline   Reply With Quote
Old 02-24-2004, 05:58 PM   #14
hammoj28
My car also has the battery under the hood but the battery box is still in the trunk even though the battery is not in the trunk.
Old 02-24-2004, 08:22 PM   #15
dansciol
