Old 02-22-2004, 11:05 PM   #1
windshield fluid problem...
Ok here is the situation. My car wont spray the window with windshield fluid, but the wipers work. basically, its not sucking water from the tank to spray onto the window. now, i checked the fuse, its fine, i swapped motors, and it still doesnt work. im beginning to think, that it is not getting any electricity running to the motor... any suggestions? my window ghets dirty fast, and its a PIA to drive...
Old 02-22-2004, 11:21 PM   #2
qimis
Mr. Euro E30
qimis's Avatar
try to poke the washer nozzles w/ neddle
qimis is offline   Reply With Quote
Old 02-22-2004, 11:27 PM   #3
im positive they are not clogged. its the motor thats not pulling the water out of the tank for some reason...
Old 02-22-2004, 11:36 PM   #4
Hook up straight 12v power to the motor, if it works then you know its an electrical problem, probably a wire.
Old 02-23-2004, 12:21 AM   #5
crazyvadim
crazyvadim's Avatar
Do you hear like a wining noise coming from the motor or the nozzles when you press for the fluid to come out?
Old 02-23-2004, 12:41 AM   #6
nop, no noise whatsoever
Old 02-23-2004, 12:48 AM   #7
crazyvadim
crazyvadim's Avatar
Well since you said the motors were swapped and you still got no fluid coming out then i would guess theres no power going to the motor.
Old 02-23-2004, 02:01 PM   #8
NickP
NickP's Avatar
I would check the wires at the base of the plug of the washer motor, alot of times they just break.
Old 02-23-2004, 06:53 PM   #9
beammer12000
beammer12000's Avatar
Send a message via MSN to beammer12000
i had the same problem and it was the wires that where broken or rusted out. trace the wire as far back as you can . iam sure that you will find the problem there. or it could be the the plug it self. use a teat light to check if you have power but some one has to be in side the car so they can push the lever.
Your Nobody Unless You Drive A Bimmer
beammer12000 is offline   Reply With Quote
Old 02-23-2004, 08:23 PM   #10
felixthecat
Was touched by Micheal
felixthecat's Avatar
maybe neither of those motors work???
Old 02-24-2004, 03:02 AM   #11
ill give all those ideas a try, and see what happens...
Old 02-24-2004, 06:41 AM   #12
P3dro
Send a message via AIM to P3dro
check and make sure your lines are plugged in. My car was in the shop last week and the passenger side was unplugged and the driver side was loose, but now they both work fine.
P3dro is offline   Reply With Quote
