Old 02-22-2004, 08:31 PM   #1
///M3
auto to manual tranny
say i bought a 1993 auto 325i and i have a e36 standard tranny clutch and flywheel. what else would i need to do the conversion also would it be worth it?
///M3 is offline   Reply With Quote
Old 02-23-2004, 12:03 AM   #2
///M3
anyone
Old 02-23-2004, 02:21 AM   #3
probably not worth it unless you can find the parts cheap and do it yourself.
Old 02-23-2004, 03:16 AM   #4
skydrvr7
you need a lot, and it is a lot of work. Unless you are really attached to your car, its better to get a new one. But heres off the top of my head the parts i used. Also, the gearing changes drastically, as the auto final drive is like 3.91 and manual is between 2.9 and 3, so that makes top speed barely 120, and a horrible freeway cruising speed rpm, so a different geared differential would be a good idea as well.
clutch kit with flywheel
driveshaft with guibo
slave cyl with hose
master cyl with hose
clutch and brake pedal housing
shifter linkage-almost $200 worth of dealer parts
possible new tranny brace
pilot bearing
Then there is some wiring to make the car start, and also to have reverse lights and cruise control. Finish with some fluids, and that should be about it.
skydrvr7 is offline   Reply With Quote
Old 02-23-2004, 03:45 AM   #5
///M3
how do the pedals match up. like is there a place to mount them of do u have to mount them urself by like welding something to the car? is it noticable after that the car was once a auto car?
Old 02-23-2004, 06:09 AM   #6
///M3
any other people have anything to add
Old 02-24-2004, 12:11 AM   #7
skydrvr7
not noticable at all. Everything is bolt-on stuff, all fitting very nicely. If you have knowledge to change a clutch, you'll figure it out. Oh, and get a bently manual.
