Old 02-22-2004, 06:11 PM   #1
Hohner
Question 318i, need help. 3 questions in one.
Hey, i've got a 1991 318i and i've got a few questions.
My primary question is about my ABS, my ABS seems to work only occasionaly and i'm wondering why. In the rain, I had to slam the brakes on, I didn't feel any pulsating in the brake pedal but my car felt like it was locking up and slid sideways in the road, and another time on dry pavement I had to slow down quickly and I heard my tires screech horribly. I wanted to see if my ABS was working or not, so I went onto a backroad and I was able to get it to activate. So my situation is, when I don't need ABS it works, but when I really need it, it doesn't work... any answers?
Secondary Question: When I have my stereo on, and when i'm driving, occasionaly I will tap my brake and the stereo will shutoff for a second, reset, and turn back on. This same effect can be caused by the brights being flicked on and off? This is also confusing me.
Other question: I've had my clutch for the 109,000 original miles on the car, and recently it's been feeling a bit 'spongy' and funny, I can pump the clutch a few times while the car is neutral and I will get the 'engaging' point to normal. My pedal pressure changes everyday, from supersmooth and nice to fairly stiff. Hmm.
Hohner is offline   Reply With Quote
Old 02-22-2004, 06:14 PM   #2
NickP
NickP's Avatar
1) Does your ABS light come on in the instrument cluster?
2) Sounds like a ground issue, some people have experienced this when reusing the stock ground with an aftermarket unit.
3) Sounds like your clutch slave cylinder is on the way out.
Old 02-22-2004, 08:27 PM   #3
Hohner
No, the ABS light does NOT come on, a long time ago it did turn on but turned off after turning the car on and off again.
How would touching the brake pedal turn off the stereo and turn it back on?
Old 02-22-2004, 08:52 PM   #4
felixthecat
Was touched by Micheal
felixthecat's Avatar
it sounds like a weak alternator,i had that problem in my 318i,as for the abs i have no idea???but if you need a control unit i have one here(dont buy a new,i heard there like 1400$)
Old 02-23-2004, 12:29 AM   #5
crazyvadim
crazyvadim's Avatar
1.I would guess its the ABS sensors,usually thats the problem that most people have.
2.Do you mean your lights flicker or dim sometimes?? if so thats sounds like your alternator is gonna be going out soon.
3.I would have to agree with NickP,sounds like the clutch cylinder.....i would suggest also replacing your clutch while your at it.
Old 02-23-2004, 12:32 AM   #6
Hohner
No, the lights don't flicker. When I tap on the brake (not everytime I tap on the brake, but sometimes) or when I flash my brights, the stereo resets.
Old 02-23-2004, 12:46 AM   #7
crazyvadim
crazyvadim's Avatar
You brought the car this way??
probably something wrong with the wiring.
Old 02-23-2004, 01:17 AM   #8
Hohner
Well, if it is help me pinpoint it.
Old 02-23-2004, 01:23 AM   #9
crazyvadim
crazyvadim's Avatar
Wish i could,im not really good with electrical.Did you buy the car with this problem??
Old 02-23-2004, 05:01 AM   #10
Hohner
Hmm, my dad said he noticed it halfway through the life of the car not when he first bought it.
Old 02-23-2004, 08:57 AM   #11
felixthecat
any corrosion under the hood?battery terminals?
Old 02-23-2004, 01:55 PM   #12
NickP
NickP's Avatar
Its not an ABS sensor, if a sensor returns an outlier reading, the ABS system stops working and the lights come on.
Old 02-23-2004, 01:56 PM   #13
NickP
NickP's Avatar
I don't know how to explain it, but I had this happen with an aftermarket deck reusing the stock ground. Using a new ground resolved the issue.
Old 02-23-2004, 02:33 PM   #14
chromius
chromius's Avatar
I had similar probs with an aftermarket, but it wouldn't reset the stereo, the sound would just get all quiet, and crackily, I pulled the stereo out ran a new ground with some 14 guage wire, fixed the problem.
