Old 02-22-2004, 12:37 AM   #1
E46coupe
E92 M3
E46coupe's Avatar
rear height..
hey guys do you think my rear looks to high. I droped the car using uuc and took some shots the other day. Can the rear springs be improperly installed?
E46coupe is offline   Reply With Quote
Old 02-22-2004, 08:55 AM   #2
Bliss
Administrator
They look fine to me...although i'm not sure how much of a drop the UUC springs are supposed to give, but it looks about right by comparing it to the front.
Also, remember that the springs need time to settle a little bit.
For maXbimmer decals, please email info@maxbimmer.com
Old 02-22-2004, 11:10 AM   #3
E46
are they the uuc v2 ?
2002 325Xi Sport Wagon
www.europrojektz.com - Europrojektz Northwest
E46 is offline   Reply With Quote
Old 02-22-2004, 03:36 PM   #4
E46coupe
E92 M3
E46coupe's Avatar
ya there v2's
Space Grey,Fox Red,DCT,EDC,Swift Springs,Carbon Fiber Roof,Diffuser,Splitters,Carbon Mirrors,M Performance Exhaust,ZCP Wheels,Caron Fiber Roof,15/12.5 spacers
Old 02-22-2004, 04:31 PM   #5
How long have they been mounted? Give them at least a month to settle into their proper height, as Bliss pointed out.
Old 02-22-2004, 04:35 PM   #6
SpoolinS6
SpoolinS6's Avatar
they will sag over time
so wat bliss said is right
or depending which lowering spring you also bought man ! if it was a slam spring or just a tuck spring ........
2000 Jetta tdi Bagged
1995 Audi S6
HI BOOST
Old 02-22-2004, 05:02 PM   #7
E46coupe
E92 M3
E46coupe's Avatar
well it's been a about 2 months but the car has been sitting in the garage for the most part of it. is it possible that the rear springs are not fitted or installed upside down...??
Old 02-22-2004, 08:47 PM   #8
Bliss
Administrator
If i can remember correctly, you can't fit the rears upside down, someone correct me if im wrong. If your car is just sitting without driving it, the springs won't settle. You need to drive it in order for them to settle properly.
I personally think it LOOKS ok. Unless you're hearing noises, and feel that they aren't installed properly, i wouldn't worry about it. The H&R race springs are MUCH higher than that in the rear for the E46's. The lowest drop in the rear for the E46's that i have seen with only springs are the Eibachs.
Old 02-23-2004, 03:23 AM   #9
E46
V2 springs dont sit that high, even if they need time to settle they wont drop that much more.
Theres something wrong.
Intrax supersport's has a pretty crazy rear drop too.
Old 02-23-2004, 03:28 AM   #10
E46coupe
E92 M3
E46coupe's Avatar
what could be wrong. the box said springs for e46 sedan or coupe. and they are v.2. this is another pic of v.2's same set up. do you think it looks the same
Old 02-23-2004, 03:35 AM   #11
E46coupe
E92 M3
E46coupe's Avatar
pic
Old 02-23-2004, 03:36 AM   #12
E46coupe
E92 M3
E46coupe's Avatar
older version v1's
Old 02-23-2004, 01:07 PM   #13
E46
oops, sorry i was thinking about the V1 in my last post
your drop looks the same as the uuc pics so i guess nothings wrong
the v2 sit pretty high in the rear
Old 02-24-2004, 06:35 AM   #14
pip328
Send a message via ICQ to pip328
Re: rear height..
I like it as it is. It's good. The silver coupe before in my opinion is too low.
pip328 is offline   Reply With Quote
Old 02-24-2004, 07:16 AM   #15
Jase
twisted beyond reason
Jase's Avatar
some springs are different front and rear. the back would be naturally higher. looks good to me
