Old 03-23-2004, 10:07 AM   #46
GusRacer
dude...the VIN site is http://www.bmw-z1.com/VIN/VINdecode-e.cgi
should tell you what ya car is....should look good...im a fellow black lover...go the jungle
www.bimmersport.co.nz
NZ BMW
GusRacer is offline   Reply With Quote
Old 03-23-2004, 02:29 PM   #47
diegom6
Originally posted by MorningCruiser
My jeep has an indicated redline of 5500rpm, but the tach goes to 8000rpm and the engine revs to 7500 before it hits a revlimiter Stock too...
what Jeep do you have? ECU controlled if so there is no way to revp up t7500 or so..
I f you don't have that tank reservoir of fluid for the steering power, means that your car didn't come with P/S from factory..
Take a pic from your tach, I wanna see it..but I bet it's a ETA model in all the way!
diegom6 is offline   Reply With Quote
Old 03-23-2004, 06:01 PM   #48
hammoj28
Thanks for all the help guys.
hammoj28 is offline   Reply With Quote
Old 03-25-2004, 08:27 AM   #49
nzer
nzer's Avatar
dude did you read anything?
Its not an eta!
BMWs Downunder
http://www.bimmersport.co.nz
nzer is offline   Reply With Quote
Old 03-25-2004, 09:26 AM   #50
MorningCruiser
MorningCruiser's Avatar
Actually, the ECU has a speed governor, and the rev limiter is WAY too high for what the engine should take, it sounded like a bomb and yes, it still runs.
92 YJ 2.5l... And no, it was not a forced rpm from downshifting or coming down a steep hill...
Wheelman for hire - PM me for details - Any Police on the forum ignore this...
Originally posted by AlpWhitE46
"Im sickfinga, im always right."
MorningCruiser is offline   Reply With Quote
Old 03-25-2004, 01:43 PM   #51
diegom6
Its not an eta!
so...if is not a ETA what the hell is ????
just see the old type of distributor, all the hoses all the parts and if you know about E30 you should know that is a ETA model...enough!
Old 03-25-2004, 02:13 PM   #52
hammoj28
Apparantely someone said it's a euro m20
Old 03-25-2004, 07:21 PM   #53
Skunk#1
the tach from a four cylinder wont work with a six cylinder, they have different readings. one picks up every four sparks and says that is for 2 rpms and the other picks up every six and says that is for 2 rpms. so if you use the four cylinder one with the six than it will read higher i think?! i know when you buy aftermarket (ie autometer) then they have a switch that you can toggle for different uses. i doubt that the bimmer one will, but you should be able to modify the tach from another six to your harness.
BMW--Because Mine Won
Old 03-25-2004, 07:22 PM   #54
Skunk#1
also he said it was a 316 with motor swap, so why would he need to find out the vin to find out what his car came with?
Old 03-25-2004, 07:55 PM   #55
hammoj28
I heard that there is a calibrate thingy behind the dials which you adjust for different engines.
Old 03-25-2004, 08:21 PM   #56
hammoj28
Old 03-26-2004, 11:46 PM   #57
nzer
nzer's Avatar
Because.. ITS A EURO m20 b20 or b23! ETAs were ALLLLLL Motronic.. Not L-Jettronic like the one in the picture is.
ANNNDDDD We don't get etas in Euroland.
BMWs Downunder
Old 03-26-2004, 11:48 PM   #58
nzer
nzer's Avatar
If that IS a motorswap - then damn it looks like it came straight out the factory . It is IDENTICAL to my engine bay.
That is no motor swap - and it is no 3 ltr motor.
BMWs Downunder
Old 03-27-2004, 12:14 AM   #59
hammoj28
It's definately a swap because the car used to be a 316i. The car has 316i on the V5 and the marking inside the drivers door says 316i. I don't think it's a 3ltr though. I will try to contact the guy that did the swap and ask him.
