Old 02-15-2004, 04:49 PM   #1
6piston
how'd he do this to his sides?
normally when the side rubbing strips/ trims are removed, it'll look like this right? (andre's) look closely.
but i'd love this look when i go paint my car.
in the pic attached...
did he attached some sort of panel onto the sides? or is this how cabrios are made?
thankS!
cheers
Tom
2.5|Unichip|MAF conversion|M50 Injectors|Coilovers|AC Schnitzer exhaust|Replica ACS Body|Replica AC Schnitzer Type 2 wheels|Pioneer DEH-P6850MP|crystal headlights|LED tail lights
Will soon be a V12!!http://www.euroasians.net
http://www.bmwclubmalaysia.com
6piston is offline   Reply With Quote
Old 02-15-2004, 05:17 PM   #2
Euro_E30
Euro_E30's Avatar
i did the same to my car it takes alot of sanding though...i took off the mouldings welding metal where the holes were and filled it with fibre glass...came out good i like it much better than having the mouldings.
Euro_E30 is offline   Reply With Quote
Old 02-15-2004, 05:28 PM   #3
6piston
huh?? that's funny.. i mean the bottom looks like it is a panel by itself.. much like the M3's.
if you filled the "drain" with fiberglass, won't it be looking flushed??? can you tell me more please euroe30??
Old 02-15-2004, 05:39 PM   #4
Slowered318
I think basically you want it to match the ridge on the top of the doors and fenders.. If you fill it in completely it won't look good at all, and the indent is deeper on the bottom of the molding then on the top.
Good luck.. it's going to take many hours of block sanding, but it's well worth the time!.. you should use the Breyton side skirts to cover the rockers and a Lumina front spoiler clip.. it will look titties!
Old 02-15-2004, 05:59 PM   #5
6piston
hi slowered. no no. i want it to look like the convertible or the M3.
hmm you mayb be right about the bottom indent being "outer" than the top.
i need a new paintjob so i was thinking if my paintmaster can do it...
thanks slowered for confiming the indents!
cheers
tom
Old 02-16-2004, 03:28 AM   #6
beammer12000
beammer12000's Avatar
Send a message via MSN to beammer12000
what do you guys think about doing this way with no line at all? its not finished yet but you should get the picture.
Your Nobody Unless You Drive A Bimmer
beammer12000 is offline   Reply With Quote
Old 02-16-2004, 03:32 AM   #7
Euro_E30
Euro_E30's Avatar
slowered is right the lower part of the molding is a little deeper u just have to make sure that when u fill it in its perfectly straight and that the ledge is the same all along the car..it takes a really long time but good luck i think it will look amazing especially on ur car and that color..
What do u mean no line???? r u gona fill in that whole area and make it completely flush..meaning from the moulding all the way up to the door handle?????
Old 02-16-2004, 03:33 AM   #8
AndreNY
AndreNY's Avatar
tom when you remove the modlings there are holes in the door and quaterpanel, which hold the clips for the moldings, those have to be closed off, and that's it. Not a big job at all
Down and Out that's the way to go...
AndreNY is offline   Reply With Quote
Old 02-16-2004, 04:48 AM   #9
lvan
lvan's Avatar
Andre's car is BOMBICA .it's p[imp as hell.
Old 02-16-2004, 03:35 PM   #10
6piston
beamer.
umm, i don't really fancy that look but it should look damn smooth if there's no line where the rubbing trims were.
andre.
thanks!
yup! and i want to do it like Euro_E30.
where there's only 1 line. which i think looks great!!
Old 03-07-2004, 06:25 PM   #11
beammer12000
here's the new look
Old 03-07-2004, 06:50 PM   #12
hammoj28
I know that this is off topic but could anybody tell me info on the silver convertable in post one. What wheels, kit and any other stuff done to it. It's one hell of a nice car.
Thanks.
hammoj28 is offline   Reply With Quote
Old 03-07-2004, 07:48 PM   #13
jeremy
-rh zw1 wheels
-e46 m3 look front bumper
-e36 m3 look side skirts
-e46 m3 side vents
-m3 look mirrors
-eyebrows
-no idea on the rear spoiler ...looks custom
Old 03-07-2004, 09:44 PM   #14
hammoj28
Thanks. Maybe the spoiler is from another car.
Old 03-09-2004, 03:23 AM   #15
Boris The Blade
Hey Euro_E30,
roughly how long of a process is it? I'm getting ready to order my kit in a week and I'm wondering if i should go crazy on the car and fill the channel or not. I really think that the car will look slammin with the color I have in mind if I fill the channels.
John!
Boris The Blade is offline   Reply With Quote
