Old 02-14-2004, 01:41 AM   #1
Gurvinder
looking for a e36
hey wats up guys i started to look for a e30 but parents think its to old so im lookin for a e36 4 door for under 10 grand if ne knoes of ne plz let me know
thanks
cheers
Gurvinder is offline   Reply With Quote
Old 02-14-2004, 03:52 PM   #2
1BADBMR
Check your message
_____________________________________________
98 M3 Sedan (SOLD)
06 Yamaha R6 (SOLD)
04 Honda Civic (Beater)
93 318i (SOLD)
1BADBMR is offline   Reply With Quote
Old 02-14-2004, 04:02 PM   #3
1BADBMR
its the green one
98 M3 Sedan (SOLD)
06 Yamaha R6 (SOLD)
93 318i (SOLD)
Old 02-14-2004, 04:09 PM   #4
Autotechnica
Little Chino
1BADBMR,
Do you have any parts off your car for sale? The 318's coils for example?
Thanks,
Bry
Old 02-14-2004, 04:27 PM   #5
1BADBMR
Originally posted by Autotechnica
1BADBMR,
Thanks,
Bry
Sorry Bry,
I plan to swap my coilovers on the 318i (PSS) & put them on the M3 and put back the stock suspension on the 318
98 M3 Sedan (SOLD)
06 Yamaha R6 (SOLD)
93 318i (SOLD)
Old 02-14-2004, 04:30 PM   #6
Jon@Bimmersport
Jon@Bimmersport's Avatar
if u need that suspension, let me know Al!
btw..i told gurvinder how sick ur ride was
Old 02-15-2004, 01:02 AM   #7
djcontra
Gets Blown Daily
djcontra's Avatar
I've got a 325i for sale for $8000 (firm).
just pm me for details if you're interested.
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
Old 02-15-2004, 01:17 AM   #8
Soldo
Soldo's Avatar
I don't think the PSS will work on the M3, because of the weight difference, due to the engine, the shocks are designed differently!!
I wouldn't suggest doing that, your better off parting the PSS' and selling the car with factory suspension!
Keven Soldo
Old 02-15-2004, 12:45 PM   #9
1BADBMR
Your right Kev,
I know this will not be a direct swap. Something with the shock mounts
But I found out from a couple of mechanics & they told me it is still possible to install them. (with a little custom work)
I really don't want to let these go. By far I think this is the best money I invested into my car.
98 M3 Sedan (SOLD)
06 Yamaha R6 (SOLD)
93 318i (SOLD)
Old 02-15-2004, 02:49 PM   #10
Autotechnica
Little Chino
I was going to say that too. I think the rear will fit without problems. But the front has problems. The M3 front struts are different than the 318 struts. The strut hats are different. You should also check to see if the tabs come welded into the PSS for the 318. If not, you have no way to reattach your front M3 sway bar.
The weight difference is a big concern. You should compare the size of 318 springs and M3 springs, very big difference.
Not trying to convince you to sell, but those are some serious factors you should consider. Personally I wouldn't do it. The M3's suspension was balanced perfectly and changing to the PSS will probably upset the balance. I'm not sure how coilovers work, but when you use a front set of springs meant for a lighter car on a much heavier car, the spring will compress (your car will be lower). The problem with this is, the front spring's progressive spring rates will be very different than the rear. Where the rear springs aren't compressed as much as the front due to their weight, the spring rates in the rear will be a lot less than the front causing unbalanced handling. This is only by theory, who knows how it will actually handle. It depends fully on how progessive the springs are. Most "street" lowering spring applications have a "comfort" zone, then a really agressive spring rate. As you start to corner harder the springs compress so does the spring rate. That's a good reason why you should never mix and match springs.
Bry
Old 02-15-2004, 05:50 PM   #11
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Send a message via MSN to AlpWhitE46
Re: looking for a e36
thanks
cheers
Well did you check autotrader?
AlpWhitE46 is offline   Reply With Quote
Old 02-16-2004, 08:48 PM   #12
Gurvinder
hey wats up guy dose ne one know where i can get a hold of alvin ne help is good thanks alot
cheers
Old 02-16-2004, 09:44 PM   #13
bcupic
bcupic's Avatar
check your pm
bcupic is offline   Reply With Quote
