Old 02-12-2004, 07:02 AM   #1
LowBMW325i
Blinker Problem
My left blinker has not been working for a while, and i have to go through inspection now, and of course it won't pass with this problem, i was wondering if anyone could help, or has had the same problem.
I replaced the relay, and it wasnt that, and replaced the whole switch altogether, and that didnt fix the problem, just wondering if it the ground would be seperate from the right blinker ground, or if anyone knows the colours of the ground or power wire, any help or suggestions would be appreciated, i need this fixd by friday night.
peace
-Core
(OO=[][]=OO)
LowBMW325i is offline   Reply With Quote
Old 02-12-2004, 06:08 PM   #2
chromius
chromius's Avatar
I had/have the same problem with my right blinker, and as far as I can tell its a loose ground somewhere, If I take the wires from the turn signal and follow them back a little ways, and move them around, it will start to work again....and it will continue to work for several weeks to several months, then stop again...I havn't fixed it perminatly, because I figure its just as easy to shake the wires every few months....so if you have the same problem...try that, it might at least work long enough for you to get through inspection.
Old 02-12-2004, 07:59 PM   #3
LukeE30IX
My fornt blinkers have never worked. And it suck going through intersections...... At first i thought it was the Bulbs... wasnt.
Checked around for grounds, i found one set of wires grounded to the body under the hood but i didnt mess with themm Im doing my brakes today, ill check that out. Ill post more after i check that out.
Check out Our site,
www.frostyle.com
LukeE30IX is offline   Reply With Quote
Old 02-13-2004, 02:15 AM   #4
LowBMW325i
well i have been checking my grounds all over tryin to find the right ones, no luck so far, everything seems to be working right, and yet no fix
-Core
(OO=[][]=OO)
