Old 02-11-2004, 06:53 PM   #1
Marecar
Send a message via ICQ to Marecar
Engine Misfire question
My buddy has a problem with his 2000 328I
on a cold start engine will rev at 1000 RPM and all of a sudden it will rev up to 2000 and drop to 500 with out pressing the gas. while its going from 2000 to 500 all the lights go dim like the batery dies and it will stall and goes back up again, then does this all over again.
he hooked it up to a computer in a shop and it says cylinder5 missfirebut when he changes the sparkplug it does the same thing.
Any suggestions?
oh yea he took it to the bmw dealership and they say its all good.
Speed never killed anyone, its the sudden stops that hurt!!!
Marecar is offline   Reply With Quote
Old 02-11-2004, 06:55 PM   #2
MorningCruiser
MorningCruiser's Avatar
If BMW says it's all good either they're lying or it's true...
Has he tried changing spark plug wires?
MorningCruiser is offline   Reply With Quote
Old 02-11-2004, 07:34 PM   #3
Marecar
It cant be good when the engine is going crazy !!!!! and theyr not lying eather cause when they checked it the checkengine light wasnt on.
I had a similar problem on my 2002. my problem ocurred only at start and when i shut it off and start again everything is fine and there is no check engine sign, and they told me the first time it was ok cause there was no check engine while it was in the shop.
he tried switching the cables and it still gave the same thing.
Old 02-11-2004, 08:34 PM   #4
DbIiRrTdY
did your o2 sensors get replaced recently?
DbIiRrTdY is offline   Reply With Quote
Old 02-11-2004, 09:54 PM   #5
djcontra
Gets Blown Daily
djcontra's Avatar
It's probably either the ignition coil going bad, or the crank position sensor.
I had the same problem on my car, it would either feel like it's stumbling upon acceleration, or sometimes during driving, the car would just die for no reason.
I had to replace both because both items went bad at the same time on my car, but both can cause similar problems. If the car doesn't die, or stall on it's own, I'd blame the ignition coil first.
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
Old 02-11-2004, 11:46 PM   #6
mpower1226
mpower1226's Avatar
it could be number of things but, two things that comes to my mind are ignition coil wires going bad and/or spark plug.
I had a similar experience and it was a spark plug being cracked.(cheap shit!!!) I changed rite away, the problem gone
Old 02-12-2004, 02:28 AM   #7
Marecar
thanks guys
