Old 02-09-2004, 02:14 AM   #1
objec
Send a message via AIM to objec
bypass AFM ???
can the air flow meter e30 and e30 m3 be taken out some how? and the car still preforms as good or better.
objec is offline   Reply With Quote
Old 02-09-2004, 02:17 AM   #2
LukeE30IX
Your a moron, you need that sensor for the engine to run.
Check out Our site,
www.frostyle.com
LukeE30IX is offline   Reply With Quote
Old 02-09-2004, 02:46 AM   #3
89325iturbo
You can take it out, but you need something else besides the stock ECU to control the A/F ratio. Either a stand alone engine management sytem, or just the stand alone fuel management. A couple people use the megasquirt, with a map sensor for the most affordable route. You can't just take out the AFM, and be all said and done, and have your car work fine if that was the case no one on this board would have an AFM in there car.
89325iturbo is offline   Reply With Quote
Old 02-09-2004, 03:07 AM   #4
objec
if the afm is not there it wont start.
Old 02-09-2004, 03:25 AM   #5
diegom6
Your a moron
hahahahahahaha
anywqays...the car can start with out the AFM, you can't run you r bimmer with out a AFM...you can swappa bigger AFM from the M30 engine and swapp also the electronic part inside the meter....as I did it and many other guys did it!
diegom6 is offline   Reply With Quote
Old 02-09-2004, 03:58 AM   #6
objec
diegom6
what kinda of exhaust manifold you you have, is it custom.
how much psi do you run, do you have a bov, how does the manual boost control thing work on yours.
is it better to put your afm where you have it or inbetween the air filter and turbo?
Old 02-09-2004, 03:59 AM   #7
BladeRunner
BladeRunner's Avatar
why does evryone give objec a hard time?
anyway i don't think your car would run.
changin oil one day forgot to reattach and secure the sensor car would start but just barely. it run for three seconds then shutdown. tryed starting and taping the throttle. i pushed the throttle one inch and my RPMs went to 6k easily.
Mad E30 lover
BladeRunner is offline   Reply With Quote
Old 02-09-2004, 04:01 AM   #8
BladeRunner
Originally posted by objec
diegom6
a thrad about his car can be found on the first page of the e30 section of Max.
Old 02-09-2004, 04:03 AM   #9
objec
cool
Old 02-09-2004, 07:50 AM   #10
jimmyd1
Actually you can completely bypass the AFM, but it would require you to completely reconfigure EFI system, including a new ECU, FMU, Sensors, etc. The system requires you to replace you crank pulse sensor, with a four sensor crank pulse system. I will try to get the info to you. Everything runs about $1500, but you supposedly gain somewhere between 15-30 hp. It would be far easier and cheaper to run a plug in MAF . You can get them from Pro-M and Split Second. They run between $700 and $1000. You make the call.
jimmyd1 is offline   Reply With Quote
Old 02-09-2004, 02:00 PM   #11
chromius
chromius's Avatar
You should read some of his other posts...thats why everyone gives him a hard time, cuz he's full of $hi#.... He already has an 800hp e30 M3 twin turbo and his non turbo e30 325e already has 250hp
http://www.maxbimmer.com/forums/show...threadid=28320
Old 02-09-2004, 02:01 PM   #12
diegom6
diegom6
see here..--->My Custom Turbo Header
I went that route cuz I thought it will be more accurate in metering the flow rate...you can put the AFM before too, but I don't know how it will respond...some puts before and other after...maybe is not much difference, dunno
Old 02-09-2004, 03:52 PM   #13
objec
thats cool how you did that, i was going to do the same thing, but i found the 524td manifold for very cheap, you said it might need to be trimmed, what did you mean buy that diegom6.
Old 02-09-2004, 03:56 PM   #14
objec
aslo diegom6, do you use a bov, on you turbo system, and how much more boost did that manual boost thing give you.
Old 02-09-2004, 04:14 PM   #15
diegom6
I'm using Apexi Twin Chamber BOV, sounds great... here some pics..
