Old 02-08-2004, 04:12 PM   #1
High beam problem...
Ok, as you all know, i dont have the center high beams, but my outer lights, ALSO have high beam bulbs in them, so i had the benefit of both, until yesterday. I wanted to flash someone in front of me for going slow on the 400 (below 150), and i noticed that my lights completely shut off when i pulled the lever towards me to flassh the High beams... is it becuase the high beams in both lights burned out, since i drove with high beams only for about 2-3 weeks, or is it something else?
I just cant figure out, WHY i would have high beams and they would BOTH all of a sudden stop working... btw i have the normal sealed beams..
Old 02-08-2004, 05:27 PM   #2
SebSter
SebSter's Avatar
yea most likely the highs in both bulbs wore out, its like 20 bucks for a new light at canadian tire i think
SebSter is offline   Reply With Quote
Old 02-08-2004, 05:29 PM   #3
thanx man... cuz i checked the fuses, and the relay, and they all seemed fiine...
Old 02-08-2004, 05:43 PM   #4
SebSter
SebSter's Avatar
yeah, same thing happened to me on my drivers side when i put on the high beam only the bulb toward the middle goes on, the one on the side shuts off.. so i need to get it changed too, i was thinking to do the upgrade to those hella h4s, i remember someone had a set for 80 bucks and they're just plug-n-play swaps
Old 02-08-2004, 06:24 PM   #5
BLAGUSS
Me too . When i put high beams on my passanger side regular light switches off. In that case all of them work but one on passanger side. What bulb do i need and How much should it go for? It is not ugrent but it bothers me when the passengers side turns off.
BLAGUSS is offline   Reply With Quote
Old 02-08-2004, 07:24 PM   #6
BladeRunner
BladeRunner's Avatar
yeah the hella replacement H1 highs h4 lows seems like a nice replacement for stock lights $45/globe. I've been saving a little here and there to get some. I might just start with the lows first to see if the highs are worth the extra money. However, if I come across some cheaply priced Ellips I may drop the hellas.
This light upgrade does scare me alittle because I don't want to produce to much heat in and around my lights nor the light wiring. The sealed beams already get pretty hot, even on low.
Mad E30 lover
BladeRunner is offline   Reply With Quote
Old 02-08-2004, 08:32 PM   #7
Terry, the highs are wired in series with the lows, when the high filament blows it cuts the power to the lows also. You need new bulbs.
I have Hella H4's, and they are frickin' amazing. And I have seen back-to-back comparison pics with Ellips, the H4's put more light on the road. If you're going to go all out and install HID then the focused nature of Ellips is the way to go, but with halogen hardware the H4's are very, very good.
Old 02-08-2004, 10:56 PM   #8
BLAGUSS
Can I do that upgrade if I have sealed beams? I just want to know.
Old 02-09-2004, 12:18 AM   #9
im just gonna do the H4;s then
Old 02-09-2004, 12:21 AM   #10
blacknblue-e30
Just black, No blue
blacknblue-e30's Avatar
Send a message via MSN to blacknblue-e30
yup highbeams both blew out, funny how at the same time both sides went.
blacknblue-e30 is offline   Reply With Quote
Old 02-09-2004, 12:43 AM   #11
SebSter
SebSter's Avatar
jay,where can i pick up the h4s?
Old 02-09-2004, 01:58 AM   #12
NickP *may* have a set, I remember he had just 1 left and someone was interested. Shoot him a PM.
Old 02-09-2004, 02:00 AM   #13
im buying Nick P's set, unless he has more...
Old 02-09-2004, 03:05 AM   #14
SebSter
SebSter's Avatar
terry u bastard, lol
Old 02-09-2004, 06:08 PM   #15
aaron_silva
You can buy them from Bav Auto or BMP. I would go through Bav Auto although both of their customer service reps suck.
Aaron Silva
1991 318iC
aaron_silva is offline   Reply With Quote
