Old 02-06-2004, 01:59 AM   #1
aaron_silva
Diff. Bushing
Today I replaced my tore up diff. bushing with a new one from a 99 M Coupe. It looks to be a lot befier. After getting a quote from the Dealership of $400 to replace the bushing, I figured f*** that... I am going to do the my own work. I was able to get all the parts (new bushing, new drain/fill plugs, gasket, and machine costs) for under $100 (big thanks to Jonathan Chan for the OEM parts :up: ).
Here are some pics of the install...
Fubar'ed Diff. Bushing
Aaron Silva
1991 318iC
aaron_silva is offline   Reply With Quote
Old 02-06-2004, 02:00 AM   #2
aaron_silva
Aaron Silva
1991 318iC
Old 02-06-2004, 02:00 AM   #3
aaron_silva
Inside the diffy...
Aaron Silva
1991 318iC
Old 02-06-2004, 02:01 AM   #4
aaron_silva
Comparison...
Aaron Silva
1991 318iC
Old 02-06-2004, 02:04 AM   #5
SpoolinS6
SpoolinS6's Avatar
looks realy good man !
btw how was the instalation on the springs on your car easy or no ?
2000 Jetta tdi Bagged
1995 Audi S6
HI BOOST
Old 02-06-2004, 02:04 AM   #6
aaron_silva
New Hotness...
Aaron Silva
1991 318iC
Old 02-06-2004, 02:10 AM   #7
aaron_silva
Suspension stuff is so much fun to work on. The rears are a piece of cake. Remove the strut bolt and sway bar link and the rear trailing arm drops down far enough for you to yank the spring out. The fronts are a little more work but it sure I fun. A buddy and I installed m3 springs on his cabrio in less that 2 hrs.
Aaron
Aaron Silva
1991 318iC
Old 02-06-2004, 02:11 AM   #8
SpoolinS6
SpoolinS6's Avatar
how much are those springs and how is the ride ? andy good or is it ruff ??
1995 Audi S6
HI BOOST
Old 02-06-2004, 02:18 AM   #9
aaron_silva
I have Ground Control Coilovers with Koni shocks (single adjustable). The ride is much much stiffer than stock but not rough. The stiffer ride is much worth the unbelievable handling.
Here are some pics...
HTH
Aaron
Aaron Silva
1991 318iC
Old 02-06-2004, 02:21 AM   #10
SpoolinS6
SpoolinS6's Avatar
looks realy realy good man !
1995 Audi S6
HI BOOST
Old 02-06-2004, 11:20 AM   #11
snd84318i
snd84318i's Avatar
why does it look like theres antifreeze in your diff . did you clean it with that or something ?
snd84318i is offline   Reply With Quote
Old 02-06-2004, 03:06 PM   #12
aaron_silva
Must be the combination of the flash of the camera and the oil gear oil.
Aaron Silva
1991 318iC
Old 02-06-2004, 04:25 PM   #13
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
The only way to replace the bushing is with the new cover?
Stanceiseverything.com
Old 02-06-2004, 04:35 PM   #14
Slowered318
Why didn't you just soda blast the old diff cover? Or is this way cheaper to replace the bushing? What brand/grade of gear oil did you use?
And where is the LSD?
Looks good though.. i like the bit of shinny under the car, did you clear coat it or is it just bare aluminum?
here is my bitch
Old 02-07-2004, 05:35 PM   #15
aaron_silva
The only reason I used a "new" cover was so I could get the bushing pushed out ahead of time so I didnt have to 1) take the old cover off 2) clean it 3) Go to the machine shop...
The diff. cover that I used looked like my old one but I used a wire brush and castrol super clean. So, yeah, it is bare aluminium.
There isnt LSD. 1991 318iC's came stock with open 4.27.
Aaron Silva
1991 318iC
