Old 02-07-2004, 12:09 AM   #1
Hohner
318i LOW IDLE THEN STALL.
I've got a 1991 318i, and when the car is warmed up the idle varies from 850 to 500. At 500, the car is shaking horribly but then it goes back up to normal idle which is about 850. The gap in the idle increases the warmer the engine gets, so when it's semi-warm it drops from 800 to 600 but when the engine is all warmed up it goes from 800 to 500'ish and then stalls. It's a weird problem, I got my engine code which was 1218 and it said online it was the Output Stage, Group 1. I have no clue what might be the problem, please reply quick!
Hohner is offline   Reply With Quote
Old 02-07-2004, 12:13 AM   #2
LukeE30IX
is you engine shaking alot, and does is sound like its running choppy, like not sounding like it used to? Start your engine and pull out each of the spark plugs one at a time to see if all of you cyliders are firing.
Check out Our site,
www.frostyle.com
LukeE30IX is offline   Reply With Quote
Old 02-07-2004, 02:51 AM   #3
Hohner
Ah, it wasn't the plugs or the cylinders ... it was the Idle Control Actuator, I fixed the problem by disconnecting the battery for ten minutes to reset the central computer which has worked so far. Any other suggestions to why the computer would suddenly glitch like that?
Old 02-07-2004, 08:43 AM   #4
LukeE30IX
Bad Grounds, would have to be the only thing i could thing of now.
Check out Our site,
www.frostyle.com
