Old 02-06-2004, 07:28 AM   #1
Powerslide
Angry e36 rattle
My rear speaker deck and sunroof control area rattle furiously and it seems like my dash is also rattling. Are there known trouble spots in e36s, and if there are, are these them? Anyone know how to dampen them w/o taking the car apart and dynamating everything?
Thanks a lot, bass rattle is my pet peeve
>>www.revscene.net<<
Powerslide is offline   Reply With Quote
Old 02-07-2004, 03:55 PM   #2
thinair
moderationistismingly
thinair's Avatar
Re: e36 rattle
I get rattling on my rear dash/speaker deck also, it seems to be caused by my third brake light.
Old 02-07-2004, 05:23 PM   #3
koncise
all you need is one mike
koncise's Avatar
Send a message via MSN to koncise
Same thing here.. but I found a little fix.
Play it so loud that you cant hear anything else
(other than that, I dunno what u could do)
koncise is offline   Reply With Quote
Old 02-08-2004, 11:31 AM   #4
Powerslide
i thought mabye if you remove the ntire rear speaker deck then put foam at the contact points it would remove the rattle. I found that if i take off the speaker grill and get my hand underneath the deck and then push up, the rattle is gone.
Problem is, dont know how to get the rear speaker deck off!
any suggestions?
>>www.revscene.net<<
Old 02-10-2004, 04:28 AM   #5
HooliGaN*
GILF HUNTER
HooliGaN*'s Avatar
Send a message via ICQ to HooliGaN* Send a message via MSN to HooliGaN*
um i think the quarter windows might be rattling aswell
happens 2 me i believe
Julian
HooliGaN* is offline   Reply With Quote
Old 02-10-2004, 11:00 PM   #6
openwheel
Gamite's Lil E34 Bitch
openwheel's Avatar
Send a message via MSN to openwheel
I had the same problem and found that the reinforcing underneath the back panel had come loose. I used some high strength adhesive and some weight and found that it has all gone away.
openwheel is offline   Reply With Quote
Old 02-11-2004, 08:07 PM   #7
Powerslide
openwheel, how did you get the panel off?
>>www.revscene.net<<
Old 02-12-2004, 02:06 AM   #8
openwheel
openwheel's Avatar
If you have a 4 door, I can help.
1) Grab the front of the bottom seat cushion and pull up, With some gentle force it will pop out.
2) Near the outboard seatbelt anchors will be a 10 mm screw. This is the attachment point for the seat back. There are generally under the plastic seat underpad.
3) When the screws are removed, slid your hands behind the top of the seat (near the headrests) Pull the left side first, then pull n the right side. This will be more difficult than the seat bottom, but they should be press fit as well.
4) This should now have the seats out of the car. The next step will be to remove the shelf itself.
5) In order to remove the panel you will have to undo the seat belts from the bottom of the floor.
6) At the front edge of the parcel shelf will be some pins, using an upholstery too, pull the pins out.
7) The shelf should now be loose, pulling it towards you, also lift up towards the ceilling of the car.
8) An viola.... I think this how to do it, I have not done it in a while
P.S. This is a method that worked for me, and by posting this does not guarantee that it will work. I will look to see if I can still find the link that helped me through it, But I have recently swtiched computers and I did not transfer all the links.
Good luck
Old 02-12-2004, 02:40 AM   #9
///MsAniTy
this audio place fxed mine and they simply put some matherial behind the rear deck and made it tighter back there and now the bass sounds amazin .
///MsAniTy is offline   Reply With Quote
