Old 02-04-2004, 02:23 AM   #1
Desisuperman
Back Brake Lights
My back brake light keeps goig out on the right side and the thing is everytime i fix it, it eventually goes out again! anybody have the same problem or have any advice on how to fix this problem?
Thanx in advance
TiMe Is NeVer WaSteD WheN YouR WaSTEd All The TiMe
01 540i-M 6spd
Desisuperman is offline   Reply With Quote
Old 02-04-2004, 02:25 AM   #2
Mikester
7th Gear Member
Mikester's Avatar
Send a message via ICQ to Mikester
ive had that prob... i went to pitstop and they fixed it... it jsut had no contact or something like that...took them 1 min to fix it (I think they cleaned it or something)
Mikester is offline   Reply With Quote
Old 02-04-2004, 03:30 PM   #3
Desisuperman
Yeah, that's what i was told. what's the best way of cleanign the contact on it?
01 540i-M 6spd
Old 02-04-2004, 03:51 PM   #4
Furious
BMW again.
Furious's Avatar
a bad contact is a very common reason for a fault on our tailights. check the contacts , clean them if you can and you should be ok.
Old 02-04-2004, 05:21 PM   #5
Autotechnica
Little Chino
The best way to to clean contacts would be to get some sandpaper or use a file and just sand down the contacts of both the bulb and the metal contact of the lens.
Bry
Old 02-04-2004, 11:08 PM   #6
325iSBimmer
///MMMM VIDA
325iSBimmer's Avatar
bend them out a little too....thats what happened to me...they weren't making proper contact
UNDER CONSTRUCTION
Old 02-05-2004, 01:35 AM   #7
Justin e36
Justin e36's Avatar
bend them.. sanding is good too... contact cleaner.. (buy from radio shack.. around $5 for a can) when you're done...
I had an aftermarket tail light that kept blowing a fuse... turned out the fixture itself was not seated totally flush and causing a short somewhere... very weird. you using aftermarket tails?
Old 02-05-2004, 01:53 AM   #8
Desisuperman
Dunno man, just bought the car littl eover a week ago, how can i tell?
01 540i-M 6spd
Old 02-06-2004, 03:06 AM   #9
325iSBimmer
///MMMM VIDA
does it have a orange turn signal
UNDER CONSTRUCTION
Old 02-06-2004, 03:18 AM   #10
Desisuperman
yup, they're the original lights
01 540i-M 6spd
Old 02-06-2004, 05:14 AM   #11
sonic07
sonic07's Avatar
i had that problem once for weeks final solution permanent fix was solder a longer contact on the socket where the bulb goes in ... and that fixed the problem for good ...
Pedal To The Metal
sonic07 is offline   Reply With Quote
