Old 02-02-2004, 08:33 PM   #1
christian
Send a message via AIM to christian
speedometer
the other day my speedometer stopped working completely. every once in a while it will bounce a little but it wont read i checked the sensor on the differential and there is no power getting to it i dont know what is wrong any suggestions ? p.s. the car is an 84' 318i thanx in avanced
christian is offline   Reply With Quote
Old 02-02-2004, 09:15 PM   #2
Jase
twisted beyond reason
Jase's Avatar
When my gauges stopped working it was the batteries in the cluster itself. they usually die after 10-15 years
Old 02-02-2004, 10:28 PM   #3
BladeRunner
BladeRunner's Avatar
aahhhhhhh good old '84 318 up to their old tricks again...
Mad E30 lover
BladeRunner is offline   Reply With Quote
Old 02-03-2004, 02:46 AM   #4
snd84318i
snd84318i's Avatar
so if change the batteries it should start working ? everything else works just not the speedo?
snd84318i is offline   Reply With Quote
Old 02-03-2004, 03:29 AM   #5
niko_gt
niko_gt's Avatar
if the odometer isnt adding up, dont worry bout it
just estimate your speed
niko_gt is offline   Reply With Quote
Old 02-03-2004, 04:23 AM   #6
christian
yeah its just the speedo everything else works, i think its effecting the mpg gauge and the odometer because the mpg gauge moves around all the time for no reason and the odometer hasn't changed milage thanx for the feedback.
Old 02-03-2004, 04:29 AM   #7
christian
hey i have another question, iv read my manual but it dosn't tell were the batteries are located or what type they are wondering if any one can help me thanx
Old 02-03-2004, 05:54 AM   #8
///m powered
dodging pylons
///m powered's Avatar
Send a message via AIM to ///m powered Send a message via MSN to ///m powered
how about this one.........
my speedo works always,
my gas gauge only has the light come on when its empty
my temp works once it gets to midway point
and my tach works when it feels like it
good old 84 318i!
edit: my odometer stopped about 5 years ago too
///m powered is offline   Reply With Quote
Old 02-03-2004, 03:14 PM   #9
Lil'Smoothie
Guest
Posts: n/a
if it was just a blown fuse than you would most likely have more than one thing out rite now, ont just the speedo/odometer
It may just be a bad connection if it is only your speedo that is out
pop the cluster out and check for a loose connection
Old 02-03-2004, 03:53 PM   #10
christian
i looked at all the connections and didnt find anything loose so i thought maybe the wire was cut i was just going to run a new wire but there are two wires of the sensor and only one on the speedo.
Old 02-04-2004, 01:00 AM   #11
BladeRunner
christian while your back there you might want change out your bulbs for new ones, save you time later.
what kind of battery is this? can i get it from BMW dealers? bulbs too? some of you might his of the dealer question as stupid but dealers don't keep up with the old stuff after a while.
oh yeah my odometer is dead too; is this fixable?
Mad E30 lover
Old 02-04-2004, 05:25 PM   #12
BladeRunner
went to a BMW dealer near me hopping to get a batteries for my cluster. Told me batteries and board come together not seperate. Price $200.60? This board better be new or very important for $200, since I must pay out of my pocket....
Mad E30 lover
Old 02-06-2004, 02:42 AM   #13
BladeRunner
oh yeah forgot to add the board may not be nessary if the rest of your gauges work, there is a follow through method to fix this problem...
Mad E30 lover
Old 02-06-2004, 10:41 PM   #14
///Mr.T
///Mr.T's Avatar
Dont buy a new board, and you dont need new batteries either.
Check out this article I had the exact same problem, and tried re-soldering the speedo. It wasnt hard to do at all, and has worked fine for 3 years!
Axis Springs
HK2 Intake
500 watt Legacy amp
Two 10 inch JLA's in the trunk
///Mr.T is offline   Reply With Quote
Old 02-08-2004, 06:46 AM   #15
Albertae30
Albertae30's Avatar
just had this prob last month everything in my car worked fine then my speedo started going crazy turns out my alternator was fried got a new one and walla
1995 VOLVO 850 Turbo
1986 Chev Camaro Z28 running 250 horse with just a stock motor and open air filter carbed.
allcanadianreject84@hotmail.com
Albertae30 is offline   Reply With Quote
