Old 01-29-2004, 04:38 AM   #1
BMW_M52_M20
Gauges work on and off........
Well the good old e30 is a bit weird when it comes to proper function of the gauges.
The Vaccum gauge has never worked since I have bought the car, and for some reason for a full day it worked and now it doesn't.
My RPM gauge tends to stop working periodically (usually if car is driven more the 30mins) and the coolant gauge sometimes just shoots past the red but when I hit the cluster, the coolant gauge works.........
The speedo works fine and so does the gas gauge, it is the right half of my gauges which work intermittently.........
Anyone got suggestions?
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 01-29-2004, 06:43 AM   #2
Albertae30
Albertae30's Avatar
had this prob with my e30 just last month it was the alternator was going so i replaced this and the ground wire from the alt and it worked perfectly no probs
1995 VOLVO 850 Turbo
1986 Chev Camaro Z28 running 250 horse with just a stock motor and open air filter carbed.
allcanadianreject84@hotmail.com
Albertae30 is offline   Reply With Quote
Old 01-29-2004, 04:43 PM   #3
BMW_M52_M20
Funny that you say that, the first day after I replaced my battery, all the gauges worked fine.
Christ, I hope my alternator isn't going, more$$$$$$$$$$
1986 325e (E30)
Old 01-29-2004, 08:56 PM   #4
Albertae30
Albertae30's Avatar
its not that much but i would fix it quick cause it will give you now warning and just quite you wont know it and then be driving down the street gauges go wacky and then it dies
Old 02-04-2004, 04:23 PM   #5
MatyBMW
MatyBMW's Avatar
Send a message via AIM to MatyBMW Send a message via Yahoo to MatyBMW
battery
My spedometre sometimes doesn't work properly. If I replace the battery, could it solve my problem?
--MatyBMW
MatyBMW is offline   Reply With Quote
Old 02-04-2004, 05:36 PM   #6
BladeRunner
BladeRunner's Avatar
might be your board and battery, my speedo doesn work which causes my MPG not to work. My tach is ok I use that when I drive usually 2kRPM in 5th means +/-50mph so 2.5k would be 60... Then again could be completely contact related.
yup had that happen to my mom and i driving down HWY and car just goes rurrrrrrrrrrrrrrrrrrrrrr stop. she tried flooring it but it was to late. i think the alt killed her practically new car battery.
Mad E30 lover
BladeRunner is offline   Reply With Quote
Old 02-04-2004, 05:50 PM   #7
BLAGUSS
if rpm gauge does not work then try to knock it. Same on mine car I knocked on rpm gauge and it works.
BLAGUSS is offline   Reply With Quote
Old 02-05-2004, 01:54 AM   #8
NickP
NickP's Avatar
Sounds like its the 2 batteries on you board... they're replaceable if you're handy with a soldering iron.
How are your service indicator lights working?
Old 02-05-2004, 01:57 AM   #9
BMW_M52_M20
Service indicator doesn't work at all, the oil service is on all the time and I have tried to reset it with the tool, but it doesn't work.......
1986 325e (E30)
Old 02-06-2004, 02:34 AM   #10
BladeRunner
the batterys are not sold seperate from the board. I was quoted $200 for board and batterys. you could always go the DIY way with soldering and desoldering tools.
Mad E30 lover
Old 02-06-2004, 05:41 AM   #11
LukeE30IX
When gauges start to go all nutty and stop working, most of the time its the grounds, your tach is connected to the distributer. Check all the grounds from your block to your fire wall or chassis, and your alternator to your block.
Check out Our site,
www.frostyle.com
LukeE30IX is offline   Reply With Quote
Old 02-06-2004, 10:15 PM   #12
MatyBMW
MatyBMW's Avatar
if anybody wants the batteries unsoldered and resoldered i can do it for you for $40 bux.. let me know
--MatyBMW
Old 02-08-2004, 02:19 PM   #13
NickP
NickP's Avatar
You can get the proper batteries at any hobby store...
Here's a link to a DIY replacement
Link
Old 02-08-2004, 05:43 PM   #14
BMW_M52_M20
Link
Thats some good info! Thanks!
1986 325e (E30)
Old 02-08-2004, 07:33 PM   #15
BladeRunner
I was looking for that site a few days ago because a few of my bubls in the cluster have bought the farm or atleast the connectors are loose.
Thanks man/lady
Mad E30 lover
