Old 01-27-2004, 04:01 PM   #1
OILERS
Front Dash Light Out
guys,
on my front dash or panel, where my knobs to turn the heater on, and the fan speed, and the temperature. and the knob that changes where the air blows, if you want it to blow on your feet or window, etc. that area, the red light behind it went out. my rear defrost and a/c lights still work. any body have this problem. what kind of light is behind that. how can i change it.
OILERS is offline   Reply With Quote
Old 01-27-2004, 05:23 PM   #2
325iSBimmer
///MMMM VIDA
325iSBimmer's Avatar
im not sure what the bulbs are...i had a box of them kicking around at the shop. but this is how you get too it...
-pull off the temp knobs and the fan and direction knobs..
-under the fan and direction knobs you'll see two phillips screws...take them out
-using a flat blade screwdriver carefully pry out the face plate....not that hard
-becarefull not to bend the face plate too much cause there are plastic rings that direct the light and one of mine is broken.
you'll see the little light...its in the middle..there is just one ligh..once you look at the back of the face plate you'll know why...
good luck
UNDER CONSTRUCTION
Old 01-27-2004, 05:57 PM   #3
OILERS
hey, thanks alot 325isBimmer. i'll try that out.
