Old 01-24-2004, 03:04 PM   #1
bmw325ix
Send a message via AIM to bmw325ix
e30 gas gauge problem
ive had a problem that seems unsolveable, the gas gauge in my e30 ix is nuts it does whatever it wants the only thing that works is the low gas warning light. if anyone has any info please help thanks
bmw325ix is offline   Reply With Quote
Old 01-24-2004, 03:35 PM   #2
Slowered318
I've heard of E30 guage clusters going for a $hit and needing replacement.. but you could always check the sending unit first in the gas tank.. maybe it's not reading a stedy voltage and needs to be replaced.. can't really help you but i've seen this on the coolant Temp guage many times
Old 01-24-2004, 05:57 PM   #3
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Clean the grounds on the back of the cluster
Stanceiseverything.com
Old 01-26-2004, 03:49 AM   #4
BladeRunner
BladeRunner's Avatar
What cleaning accessories needed? Air gun, soft brisseled brush...
Mad E30 lover
BladeRunner is offline   Reply With Quote
Old 01-26-2004, 04:04 AM   #5
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
I think you just take the cluster out and clean the corsion off with sand paper or something. It works for the temp gauge anyway.
Old 01-26-2004, 07:23 AM   #6
nzer
nzer's Avatar
check the SI board is working OK. The old batts may have leaked and farked all the traces on the board up.
BMWs Downunder
http://www.bimmersport.co.nz
nzer is offline   Reply With Quote
Old 01-27-2004, 04:31 AM   #7
BladeRunner
Sand paper ; that doesn't sound good for flow of electricity if you hand slips nad scrapes a critical point.
Old 01-27-2004, 06:24 AM   #8
SebSter
SebSter's Avatar
you know what happened to me just last week, kinda related... my computer shows whack consumption readings, the gas gauge works fine and the consumption needle under the tach works fine but my computer shows like 5.9 l/100 and a distance of 999+ on a full tank .. stupid thing
Old car 1990 325ix. Current car 2000 540i.
SebSter is offline   Reply With Quote
Old 01-27-2004, 07:33 PM   #9
chromius
chromius's Avatar
I've got the same problem on mine, and I know of several others that have had the same problem...I think it must be common...I've just been relying on KM's to know how much gas I have, and since the low fuel warning still works, I don't worry about it too much. But I wouldn't mind knowing why it messed up, I figure I will fix it some day.
Old 01-29-2004, 12:38 PM   #10
SebSter
SebSter's Avatar
my computer fixed itself...a couple of nights ago it just reset itself, liek the time/date and everything reset...and since then it shows the right readings .. weird , but i aint complainin
Old 01-29-2004, 05:24 PM   #11
tuNED318
///M Testing Engineer
tuNED318's Avatar
Same thing here, my gas gauge doesn't work and the low gas light is always on.... but every other gauge seems to work fine
Although, I miss a gasket near the filling hole maybe it has something to do with it?
tuNED318 is offline   Reply With Quote
Old 01-30-2004, 12:38 PM   #12
magnus
magnus's Avatar
just get a new gauge if the gauge is faulty! used ones are peanuts! i got a cluster with everything for about $30. As for the OBC (if thats what you re refering to as a computer unplug it and check the connector is ok and make sure its plugged in correctly and tight ! I am pretty sure though that both the fuel and temp gauge faults will only be solved for good if you replace them. Had the same problem too!
http://pics.livejournal.com/blblblblx/pic/000r554e.gif
"Lo there do I see my father.
Lo there do I see my mother.
Lo there do I see my brothers and my sisters.
Lo there do I see the line of my people back to the beginning.
Lo they do call to me
they bid me take my place among them in the Halls of Valhalla,
where the brave may live forever"
magnus is offline   Reply With Quote
