Old 01-18-2004, 11:45 PM   #1
Jammasterj
Send a message via ICQ to Jammasterj
Question Pros and Cons of Cold Air intake
Pros and cons of a cold air intake?
How much more power do you think that one could get from a cold air?
Pro
cold air
Con
hard to install
hard to clean
likely to get clogged with road dirt
subject to the elements
Your thoughts?
Jammasterj is offline   Reply With Quote
Old 01-18-2004, 11:53 PM   #2
Mikester
7th Gear Member
Mikester's Avatar
Send a message via ICQ to Mikester
pay someone 10 bucks to install it for u
i didnt install mine myself, but it seems pretty easy
Mikester is offline   Reply With Quote
Old 01-19-2004, 02:04 AM   #3
For your M? You'd be lucky to gain anything really. There are no cheap acceleration upgrades for your car save for a shorter diff.
Old 01-19-2004, 02:45 AM   #4
crusher
OMGHI2U2
crusher's Avatar
you might want to check this out.. $950 for a Gruppe M intake
http://www.e46toronto.com/forum/show...b=5&o=&fpart=1
crusher is offline   Reply With Quote
Old 01-19-2004, 03:56 AM   #5
FastM3
is dreaming of ///M's
FastM3's Avatar
Ya I suggest getting a GruppeM intake also...those are definitely the best for E46 M3's!
I know someone that has one on his M3 and he loves it, he said he noticed some power change after he installed it (himself too) and overall he loves it.
Looks great too!
FastM3 is offline   Reply With Quote
Old 01-19-2004, 04:00 AM   #6
Jammasterj
not specifically for the M
i installed one on my brothers Celica. WOW
made a huge difference, he has the GTS with the VVTI or something valve timing.
man that valve timing makes a huge difference in acceleration.that car is pretty dope and so fast at the high end
I was just wondering if it was worth the money to get the cold intake
or a regular one with a heat shield...i mean the regular one wouldn't get all the water and snow stuck in it
Old 01-19-2004, 04:03 AM   #7
Jammasterj
for the M though...
what does the exaust sound like? or the car ingeneral with an intake
i would be REALLY interested in hearing one! cuz right now it is a bit raspy
Old 01-19-2004, 04:13 AM   #8
FastM3
FastM3's Avatar
I'll ask my buddy to make a video of his.....ahhh shit actually his is stored right now so he probably can't, but I'll ask.
It sounds pretty cool, the original purr of the M still overpowers it but it's still nice.
Any CAI is going to help a regular car, but M's is a lot different. The GruppeM is worth it though, that definitely gives it an extra kick!
Old 01-19-2004, 04:44 AM   #9
notmpowered
bent rims
The stock m3 airbox is made to flow air well. You will not get gains out of an everyday run of the mill CAI. Cons=everything, Pros=none. Get the gruppe m intake, it will look hot in the engine bay
notmpowered is offline   Reply With Quote
Old 01-21-2004, 03:04 AM   #10
jmalixi
Originally posted by Jammasterj
for the M though...
I assume you're talking about the E46 M3.... The raspiness of the E46 M3 US spec is due to the design of the mid-pipe for US emission laws. UUC has a mid-pipe for the M3 designed specifically to address this problem.
Not sure if I interpreted your post correctly but an intake will not help eliminate this raspiness. Check out UUC Motorwerks if you really want to eliminate the raspiness.
Hope that helps...
jmalixi is offline   Reply With Quote
Old 01-21-2004, 04:37 AM   #11
FastM3
FastM3's Avatar
Hope that helps...
Who would ever want to eliminate the raspiness of an ///M?! That's what makes the damn car sound so tough!
Old 01-21-2004, 07:42 AM   #12
Jammasterj
Hope that helps...
Thanks man, ill check that out...
persoanlly i would like to make the M sound beefy not raspy...
like the M5!
Old 01-21-2004, 01:48 PM   #13
jmalixi
There's obviously a lot of people who want to remove the raspiness. UUC will not design and manufacture a mid-pipe to eliminate it if there's no demand for it.
Like anything else, everyone's got his/her preference. To each his own, I guess.
Old 01-21-2004, 07:39 PM   #14
Gizmo
That raspiness sound isn't just on US spec E46 M3's, here in South Africa they make the exact same sound...There are some performance shops that fix it though, I have heard the difference and it is alot more beafy!!!
Gizmo is offline   Reply With Quote
