Old 01-18-2004, 05:14 PM   #1
Autotechnica
Little Chino
How do I manually clean my ICV?
I've got an M42. I'm not having any problems with my motor, I'm just bored and want to work on my car
I figure since my car has high milage the previous owner probably has not cleaned the ICV (Idle control valve). I've read that every 80,000miles it should be cleaned. I've got 230,000km's so probably a good time to do so.
If anyone can redirect me to a site that has DIY information or just give me the gist of it, I'd apprecaite it.
And I don't care how cheap or expensive it is to have it done by someone else, I'm doing it myself dammit
Thanks,
Bryan
Old 01-18-2004, 08:24 PM   #2
Gamite
Gamite's Avatar
use a tooth brush
www.gamite.net
Old 01-18-2004, 10:32 PM   #3
Autotechnica
Little Chino
Ok.. let me rephraze the question. Where the heck is my ICV located, and how do I remove it? Secondly, what part should I be cleaning? I have no idea where this thing is located or what it even looks like. I assume it would be somewhere near my throttle body cable.
Thanks in advance
Bryan
Old 01-19-2004, 05:55 AM   #4
kco325
while you're at it, polish the outside with jeweller's rouge or a liquidy polish and a dremel / buffing wheel.
They shine right up...
kco325 is offline   Reply With Quote
Old 01-19-2004, 09:56 AM   #5
Gamite
Gamite's Avatar
Actually, I hear toothpaste works better.
Then use mouthwash to rinse it away.
www.gamite.net
Old 01-19-2004, 07:28 PM   #6
Autotechnica
Little Chino
Anyone else want to help me with this?
I'm not asking how to clean it. I'm asking where the thing is!
Thanks,
Bryan
Old 01-19-2004, 07:33 PM   #7
Jase
twisted beyond reason
Jase's Avatar
got a pic of your engine bay? I will circle it for you
Old 01-19-2004, 07:57 PM   #8
Autotechnica
Little Chino
thanks!
Old 01-20-2004, 04:57 AM   #9
crazyvadim
crazyvadim's Avatar
It should be somewhere around your throttle body i believe.
Old 01-20-2004, 06:24 AM   #10
fabianyee
It's underneath the top half of the intake manifold.
You have to remove the top of the intake manifold to get access to the ICV
Fabian
E30 318i M42B18
www.BMWClub.com.my
fabianyee is offline   Reply With Quote
Old 01-20-2004, 02:42 PM   #11
Autotechnica
Little Chino
You've got to be kidding me. That's a hell of a lot of work! I've swapped out manifolds on the M42 before and it takes hours, the fuel lines and hoses are such a pain in the ass. Are you positive about this?
Thanks,
Bryan
Old 01-20-2004, 03:57 PM   #12
fabianyee
Thanks,
Bryan
Not kidding you, it is underneath the top half manifold. Actually, you can loosen the top half manifold while keeping whatever hoses in place, just relocate it enuf for you to reach the ICV...
I know it's where I said it is, as I was there when my mechanic remove the top half manifold to replace the engine temp sensor. That was a b*tch to replace as well....
While at it, I saw the '3rd' butterfly throttle.... Interesting how this little thing can improve the low and midrange torque...
Fabian
E30 318i M42B18
www.BMWClub.com.my
Old 01-20-2004, 05:50 PM   #13
Autotechnica
Little Chino
Thanks for the info. I think that's a much larger project than I have time for right now. I was thinking of tinkering with something that would take a few hours at most.
I agree with you, the technology used in the M42 motors are quite impressive. I'm constantly impressed as I learn new things about my motor that I had no clue existed before I could do with a little more power though.
Bry
Old 01-20-2004, 07:10 PM   #14
Gamite
Gamite's Avatar
get a long toothbrush that will reach under, see! problem solved!
www.gamite.net
