Old 04-24-2002, 11:22 PM   #1
WASABI
OG
Anyone used Mother's Clay Bar?
How does it work? I'd like to do it this weekend, but have never used it before, got any tips? How well does it take out oversprayed paint?
Old 04-25-2002, 12:03 AM   #2
KIRASIR
Your Nightmare
KIRASIR's Avatar
Wash the car, then use some of the clean soapy water, take the bar and just GLIDE it over the paint on the water. Don't push it into the paint, just GLIDE! When it gets contaminated with stuff carefully fold it, and do it again. Keep on doing it till you are done with the car. The wax and polish the car.
You shoudn't use the bar often, maybe once a year at most since it's a pretty rough abrasive. Use lots of water, and just GLIDE the bar over the paint. You can use the bar on at most 3 cars then it just gets too dirty. Remember to always fold it to expose a clean surface, otherwise, it becomes a sand paper, and will scratch your paint.
SL
Old 04-25-2002, 12:09 AM   #3
330DTM
Cinematographer
330DTM's Avatar
Send a message via ICQ to 330DTM Send a message via MSN to 330DTM
Just make sure you use some polish and wax after the claying process.
I often found that if I did not do this, which i exactly did in the past, the oxidation would simply kiss onto the body panels again and forcing me to clay the car again. This being less than one month and the grime is alreayd on my car!
Then again my garage has crap and it never gets parked in the garage!
-=Slow In Fast Out=-
330DTM is offline   Reply With Quote
Old 04-25-2002, 03:10 PM   #4
WASABI
OG
sounds like i've got to be VERY careful
I'm gonna go try it out.
thanx doods !!
Old 04-25-2002, 04:27 PM   #5
KIRASIR
Your Nightmare
KIRASIR's Avatar
Re: sounds like i've got to be VERY careful
You just have to be patient. TAKE YOUR TIME!
SL
thanx doods !!
Old 04-25-2002, 07:32 PM   #6
djcontra
Gets Blown Daily
djcontra's Avatar
it might be easier to use a mild rubbing compound
but i dunno
i've never used the clay bar
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
Old 04-30-2002, 11:49 AM   #7
Softy
Clay bars are incredible for overspray and industrial contaminents. If your finish feels rough to the touch the clay bar will allow you to slide across the hood Dukes od Hazards style.
I prefer using an instant detailer of somekind as a lubricant rather than soap. Most of the clay bars out these days are non-abrasive so you can use them as often as you like, however, just be careful that you're always using a fresh part of the bar as the dirt you collect is abrasive.
If you use it and wax the car properly you won't need to do it more than once a year.
Softy is offline   Reply With Quote
Old 04-30-2002, 06:18 PM   #8
Lip
I use Zaino
Lip is offline   Reply With Quote
Old 05-02-2002, 07:00 PM   #9
WASABI
OG
I've got mother's instant detailer, will that work ?
So wash the car thoroughly, don't dry it off, spray instant detailer or soak surface with water/soap mix with sponge, skim the surface with the clay, then what , rinse, dry (chamois), and wax ???
Old 05-02-2002, 10:03 PM   #10
Softy
Wash and dry the car. Spray instant detailer as the lubricant, and slide the bar back and forth over the detailer. If it starts to dry up add more detailer. When the bar glides smoothly without catching anything move onto the next spot. Then just wipe off the detailer with a clean chamois.. if it's dried up then just use a tiny bit more detailer to clean it up.
Then make sure you wax it thoroughly.
Old 05-04-2002, 07:36 PM   #11
WASABI
OG
That worked well !!!
Thanks for the tips guys !!!
I did it this afternoon, the clay bar is on sale at Crappy tire this week. I must say it worked pretty good, I could actually hear it take the rough stuff off.
I give it two thumbs up !
